Opinions on value of this blazer needed. Thanks
I've been offered up this blazer from a friend of friend not currently advertised for sale. Its a 72 cst 4x4 dark yellow, no motor, all windows shot out by kids, nice single wall top/hatch, front bumper and grill nice, skid plate and very original hitch, tilt, nice tailgat, highlander package. Has rust on floor pan, kick plates, rear bed, driver door is shot, rust on driver wheel cover, rockers toast, tub behind wheels, rocker boxes seem good. Would like to hear what you would offer for this? Then I'll mention his asking price. Thanks for any help.
![]() Join Date: Jan 2012
Re: Opinions on value of this blazer needed. Thanks
Well, I'm far from an expert, but I'd say how much to offer depends on what you want to do with it and whether you are going to do the work yourself or pay somebody else to do it.
If restoration and keeping is your intention, you have to figure in the cost of a good crate motor ($2900), probably the alternator, power-steering pump, a/c compressor, and water pump, and radiator while you're at it, ($1000) recovering all the seats, replacing the floor covering and carpet, ($1500) the driver's door ($350), and all the glass ($1000). The body panels for the rust repair (what you can see, and what you will find later) are not expensive if you are going to do the cutting and welding yourself, but they aren't free, so I'd figure $750 for that. Also, looks like the air ducting inside would probably need to be replaced and the steering wheel. Then, it will require painting even though it looks pretty good, the new door and the scratches would be really hard to match so, you probably need to repaint the whole thing (again, if you are going to do that yourself and already have the right equipment and facility, it isn't too expensive.) And, there are probably some wiring issues from age and weathering. If it were me, I wouldn't offer more than $1500, maybe $2000, but that is from a guy who does all his own work and has one money pit and isn't looking for another one. |
X2 I would definitly say $1500- $2000 easy, If you pick it up I have all of the glass you need just north of you . Jim
39 GMC pickup,70 GMC K1500 short bed 4x4 ,72 K10 short bed step side 4x4 ,71 short bed fleet side , 72 K20 long bed ,74 K10 long bed , 69 C30 dump bed dually, 79 K30 standard cab dually , 02 Dodge 4x4 dually |
Carpe manana
![]() ![]() Join Date: Dec 2010
Agreed that $2000 seems more or less fair. I'd buy that for $2000. It helps that the dash is uncut but there's a lot of rust repair. I wonder if the firewall is rusted through anywhere...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks for the link Dirt's72.
Going to have to think on value factors and I will get back to you later. But to someone who wants those colors and options, like the camper mirrors, it is worth more as a project than to someone looking for a deal in an "off color" vehicle. Anyway here are a couple of pictures to bring you and anyone else up to speed on its glory days look. Unfortunately most pictures tend to push the color more yellow than it actually is. But then everyone has seen a school bus.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-1500 I'd say. The rust looks more surface than anything. It has most of the parts there. Could buy a junkyard engine with accessories for a few hundred. Get it going and have some fun. Lots of options on that one. Logged the highlanders.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
![]() Join Date: Jun 2000
Has some nice options on it, but as others have said, value will depend on your intended plans. Total resto, forget it. You'd be money and lack of frustration ahead to spend more $s on one that's in better shape, or that someone else has already spent the $s on. The rust/rot can be costly to repair. I'd go up to $1500.
![]() Join Date: Sep 2013
It's a highly optioned Highlander and there aren't many of them out there. I'd say jump on it.
![]() Join Date: Apr 2006
I'd pay more than 2k for it. Maybe 4 but that's me.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
$1200-2000? If you can buy it for under $2K and intend to restore it, buy it and run. I'd say you could do very little to that truck and double your money or more if you just wanted to flip it. It's a Highlander with an air-condioning dash and a single wall top in a desireable color. The downside is that it has a lot of rust made more obvious by a color that shows it off. It's a good resto candidate, and would be a very desireable truck restored, and I'm not one of those guys that thinks everything old should be restored, hell look at my build thread.
In a large West Coast market like LA, San Diego or Bay Area you could get $3500 pretty easily I would think. |
#12 | |
Thanks for all of the great replies. I ended up picking this thing up. Asking price was 4500. He wouldn't budge off 4200 and threw in a motor which ended up being a 305. Of course I couldn't resist. He didn't even know it was a highlander either. It did end up coming w/all original ps, ac, alt brackets, inside tire carrier, shroud, radiator and owners manual. I plan on keeping it as much as stock as possible. I have a 72 motor lined up. For now ill just get it running, hopefully some day restore it, or not. It's really been nice having it sit next to my other 72 cst Blazer in similar condition and compare one to the other. After closer inspection ive found it's been painted before, has some filler on rear tub just like my other. Both seem identical in the aspect they were painted and reasonably taken care of and parked for a long period of time and ended making good rat homes. Just need to look out for that hantivirus right Pete. Lol..
#15 |
...and there you go, the forum imitates life, put it out there for a little bit to a broad audience and the number will rise.
![]() I hope the seller doesn't know about this forum, if he does the price just went up. |
#16 |
Hey. I'm in New England. The hardest thing to find up here is a good body. We have small block Chevy motors coming out our ears in salty New England because the donor cars and trucks turned to brown powder and returned to the earth. Mechanicals are not the problem.
That body looks manageable. Most bodies up hear no matter if you cut the rust out and replace panels, and strip and treat and sand, the rust always comes back because once it gets down in the seams it just never goes away. Like I said, a well optioned truck, AC, etc. Absolutley. I would rather rebuild an SBC or drop in a crate motor over a weekend than spread a rusty truck out all over my garage and yard and end up making a mess and blowing brownish red snots out of my nose for weeks on end. And after all that have the rust start peaking through again after a few humid seasons. But that's just me. To each his own. |
#17 |
I'd go three pet grade puppies maybe four. :-)
#18 |
Carpe manana
How much for the Challenger in the background? Grab that too!!
#19 | |
Cluster King
![]() Join Date: Nov 2012
![]() I know someone that can set you up with a real nice gauge cluster for it also ![]()
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#20 |
Carpe manana
Glad you got it home buddy! Yes - watchout for Hanta. Take pics of the dead stuff you yank out of the duct work this time
