Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-12-2014, 08:33 PM   #1
Sillyoldman
#16876
Sillyoldman's Avatar
Best battery charger?
It's time to replace my old Century charger. I'd like 6/12v , 2-10-50 with Marine, AGM & Gel charging capabilities. Not sure whats out there these days, does this contraption exist?
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-13-2014, 03:59 AM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: Best battery charger?
Check Interstate Batteries, Grainger or Pacific Batteries. That if there is any supply warehouses down there.
oldiron is offline   Reply With Quote
Old 04-14-2014, 02:29 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
I got one of these: http://www.batterychargers.com/Produ...tName=94026976 from my local Interstate Batteries store. They recommended it as Schumacher's top notch charger. It's the XC103. I was suprised at how compact it was for the power it has.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-14-2014, 04:36 PM   #4
ERASER5
ERASER5's Avatar
Didn't you work at a battery place?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-19-2014, 10:39 PM   #5
Sillyoldman
#16876
Ya but they did not make/sell chargers. I'd never buy from them bee-stards again. Good products, maybe even the best but the guy I worked for was a horrible person.
Old 04-22-2014, 08:20 AM   #6
ERASER5
ERASER5's Avatar
I see. Bee-stards huh? Sounds like you got stung a few times.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 04-19-2014, 10:41 PM   #7
Sillyoldman
#16876
I'm digging that! Thanks for posting
Old 04-23-2014, 07:25 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Be careful when hunting for one. I had an Optima die prematurely on me one year, and I couldn't figure out WHY. It had been on an "onboard" maintenance charger from NAPA, which had always worked just fine before.
Then I found out that Optima wants a 1 AMP charge, which is extremely low. Most "snap" chargers are 2,5,10a and many maintenance chargers are 1.5-5a....which made it pretty annoying knowing a 1a was the recommended size.
I just stopped using the maintenance charger on the optima. Instead, I make sure the truck runs long enough on its "last voyage" for the year to get a full charge, then I disconnect it and keep it up off the floor. If you watch my Startup Video on my channel, it fires over first try with an Optima Blue that sat for about 6 months.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2014, 08:06 AM   #9
truckdude239
truckdude239's Avatar
sitting on the floor has no effect on them any more my redtop sat on the floor for over 8 months and she started right up.
but i have one of these for my normal batterys and a small2 amp for my optimas
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-03-2014, 05:33 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes and No.
You live in a MUCH warmer climate. Since Optima/AGM batteries are still lead-acid, the chemical reacting is still vulnerable to temperature, slowing the galvanic reaction. When you put a battery on the floor, the concrete become an area of low heat load, while comparatively the battery is "warm". The floor will draw any remaining warmth from the battery, slowing the reaction further.
IF you were to try and start something off of that battery, it would probably be dead. HOWEVER, if you let that same battery come back up to a more stable temperature, it may function again like normal...since the heat load is allowed to stay around the battery.
There is no Temperature known as cold, cold is only the absence of heat load.
Old 04-24-2014, 09:01 AM   #11
cdowns
cdowns's Avatar
i've had a battery charger that i got from sears a reasonable price and it's goin on 25years old without a problem
Old 04-24-2014, 11:30 AM   #12
NONHOG
NONHOG's Avatar
Pretty sure I have an extra you can have till you get one you want.
Not so sure you didn't give it to me few years back?
Also have that Interstate connection if needed.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 04-26-2014, 01:13 PM   #13
Sillyoldman
#16876
No need now. I took apart the old one and made an obvious fix after I dropped it. I may still look for a AGM/Marine/Wet cell charger though.
