04-13-2014, 08:22 PM | #1 |
Parts needed off of donor truck for 6.0 swap
I would like to know do I need the big fuse box panel that is located under the hood for my swap.Also do i need any of the harness that goes inside the truck or hidden sensors or switches.It is a drive by cable throttle.Do in keep the throttle cable from donor truck for my 87.Thanks in advance.
04-14-2014, 12:30 PM | #2 |
Re: Parts needed off of donor truck for 6.0 swap
the wires that go inside the cab should mostly be for the gauges and the VAT system, I'm not sure about the fuse block I would think you dont but cant say for sure?
not sure if I'll get in trouble for this but you might fine your answer here http://lt1swap.com |
04-14-2014, 12:57 PM | #3 |
04-14-2014, 01:01 PM | #4 |
you def need the pedal and pedal harness.
04-14-2014, 02:39 PM | #5 |
Slots go on anything!
I would grab the pedal just in case, but you definitely want the cable. I would try to get everything you possibly can. You can always pitch what you don't end up using.
1974 Jimmy- 5.3/4L80e/NP241 |
04-14-2014, 02:57 PM | #6 |
is it cable thottle then all you need is the cable.
