Old 04-14-2014, 11:30 AM   #1
biohazardbill
PB Narrowed arms and 22s
If you are running this setup what backspacing/tire size are you running and what issues have you ran into?
I had the regular arms and 20s but have since switched to the narrower arms so I need to order some new wheels.
biohazardbill is offline   Reply With Quote
Old 04-14-2014, 12:01 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: PB Narrowed arms and 22s
I guess I'm kinda stumped with your question.
If you were going to switch wheels,... why did you switch a-arms?
You could have got "whatever backspace you wanted" to work with the standard width Porterbuilt arms.
We need a little more info:
What year truck?
Stock crossmember?
Extreme Dropmember?
Touring Dropmember?
Mild Dropmember?
Is it even bagged?
Static dropped?
Keith
Convert to disc brakes.
Old 04-14-2014, 12:11 PM   #3
biohazardbill
Extreme dropmember, truck lays frame. I think... I bought it a few years ago. Round tube, not square.
I didnt plan on switching the wheels. When I originally bought the a-arms they were only available in the standard width (same time i bought the crossmember). At that time people were using 20s on the front when laid out.
I have since used the A-arms on a different project and when I went to order replacement arms I had the option of 1" narrower to run 22s, hence why I now want to swap the wheel size to match the rear.
Truck is a 65 Suburban
Bagged, lays frame
As far as backspacing I dont think I can get whatever I want. I have Coy wheels right now and my first experience with them was not the greatest. So anything custom from them i believe would be out of the question.
Old 04-14-2014, 12:16 PM   #4
biohazardbill
Looking at Coys site right now I may have to go with a different option....
Apparently they dont offer black C5 anymore
Old 04-14-2014, 12:29 PM   #5
biohazardbill
Now im confused... found them on the site through a google search... I am going to have to call them
Old 04-14-2014, 12:32 PM   #6
lolife99
lolife99's Avatar
If you're going to run the 22x9 up front,... I would go with the most BS that Coys offers.
That appears to be 5.5" bs.
That should work with a 1" narrowed a-arm,... but I'm not as familiar with these 60-66 trucks.
Keith
Old 04-15-2014, 01:37 AM   #7
64shortc10
64shortc10's Avatar
I have PB narrowed arms, dropmember and 22's!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 04-15-2014, 01:48 AM   #8
64shortc10
64shortc10's Avatar
22x9.5 with 5.5 backspace wheel is tucked but still a little close to the fender for low turning! Run a 265-35-22 or smaller tire! I have a 265-40-22 and it's too big touches the firewall but I'm also bodydropped 3/4 inch!
Tony from Norcal
Old 04-15-2014, 08:16 AM   #9
biohazardbill
Thanks Tony.... Mine will only be 9" wide wheels so they will tuck farther in. I cant remember the size tires I have in the rear. I will check this weekend but I plan on getting the same size. Still have not found another grill lol.
