04-15-2014, 09:21 AM | #1 |
Gas filler location?
I'm about ready to place the gas tank under the bed of my '64 stepper and was wondering something.
IF you had the choice of bringing the fuel neck out behind the license plate in the center of the roll pan or adding a fuel door to the side of the rear fender, what would your preference be? Any benefit of one over the other and any hidden issues that might pop up with either choice?
http://s994.photobucket.com/albums/af62/ScottAz2/ |
04-15-2014, 09:33 AM | #2 |
Re: Gas filler location?
Hidden behind the license plate sounds cool, but I think it would be a pain in your back trying to fill. Also it would be a rather short neck and would have to a sealed tight cap. I would go w the factory style flip door.
04-15-2014, 10:06 AM | #3 |
C10 CLUB Y QUE!
i did mine in the driver side stake hole
04-15-2014, 03:29 PM | #4 |
I don't have stake holes any more....welded them all up when I frenched in the Cadillac tail lights.
04-15-2014, 04:25 PM | #5 | |
C10 CLUB Y QUE!
04-15-2014, 04:01 PM | #6 |
I've been looking at options for this as well. Good idea on this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=197895
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
04-15-2014, 04:26 PM | #7 |
I would either do behind the license plate or figure out a way to have one of the bed planks on hinges.
04-15-2014, 04:51 PM | #8 |
I love the hinged plank idea, as I've seen it before. However, I just know that I'd forget to make sure the nozzle was empty before holding it over the bed and the residual fuel in the nozzle, left by the previous user, would pour out over my bed.
04-15-2014, 04:59 PM | #9 |
Mine is inside the bed on the floor of my fleetside.....
http://kieth.smugmug.com/Trucks/66-GMC/i-5cxcPkV http://kieth.smugmug.com/Trucks/66-GMC/i-sMtpxWj |
04-15-2014, 05:43 PM | #10 |
I say add a door to the driver's side. That is what I plan to do some day. It also somewhat depends on what your plans are for the truck. I considered behind the license plate, but figure that will be a pain if I have a trailer hooked up, and the bed floor is out of the question, because I plan to use the truck to haul.
That's just my $0.02... good luck. |
04-15-2014, 07:19 PM | #11 |
I just built my tank the other day. I put filler neck on driverside bed floor behind wheel tub so if I have a sheet of plywood drywall what ever I.can get to it
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
04-15-2014, 07:44 PM | #12 |
I used one of the motorcycle "Pop-Up" type filler caps on the driver side fender. I used some of the hose that Lowes sell that is gas safe and some 1.5" exhaust pipe bent to make the tight bends. I am very pleased with the outcome.
04-15-2014, 08:02 PM | #13 |
Any pics T2vigil?
04-15-2014, 08:20 PM | #14 |
I also plan on installing an under the bed tank. Nosing around the wrecking yards the square fuel doors from a Ford Fairmont or a Chevy Astro Van look like a very good candidate to weld into my 64 fleet side bed. Just a thought.
04-15-2014, 11:24 PM | #15 |
Great intel, Terry. I prefer the square door as well.
04-16-2014, 01:22 AM | #16 |
I went drivers side fender.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
