Extended brake flex lines (4x4)
I have a '69 4x4 and I added a lift to it. The outer covering of the flex brake lines have a few cracks and they seem a little too tight. I'd like to get new flex lines that are about 4" longer. I tried a company in town that specializes in custom hose and brake lines, but they had trouble finding the frame side fitting.
Someone must have done this previously? Any tips on where to find the fittings or get lines made up? Gracias! -Steve
1969 Chevrolet 4x4 C10 Pickup |
One of the First
![]() Join Date: Jan 2000
Re: Extended brake flex lines (4x4)
In-line tube...
They're probably talking about where the hose goes into the frame bracket and then clips on? If so, you can probably use a fitting from a later model hose (73-87). I'm doing a rear end swap. 68' H052 to a 75 14bolt. I ordered a rear brake hose for 75 and while it has 1 narrow tab and 1 wide tab instead of a hex pattern, it still fits and locks into the frame bracket.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
![]() Join Date: Jun 2012
I used Kore3. They will custom make your lines with the correct ends. My only complaint is that they took a couple of weeks to get.
http://www.kore3.com/
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
![]() Join Date: Feb 2014
inline tube x 2 also try classic tube
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Inline tube X 3. I used them for my K10 lift. Bought the braided steel with black covering so they look somewhat stock.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Offroad Design.. Be sure there is still flex on the hoses when the axles are at fully extended position
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Thanks for all the tips.
Ordered from Inline Tube. Aaron, the guy who hooked me up, seemed to go out of his way to make sure I got what I needed. A rare commodity these days. -Steve
