Old 04-15-2014, 02:32 PM   #1
dremmick
Fuel issue?
I have a 67 long box that I recently took out of storage and has not been ran in 5 years. Suprisingly the truck fired right up! I changed all the fluids and added a inline fuel filer then started the 2 hr drive home. After about 30 miles of running great all of a sudden the eingine was surging/starving for fuel. So i pulled over and let it sit for 5 mins. Then went down the rode 5 miles and did the same thing. If i let it set for 5-10 mins it runs good for only 5-15 miles.
So I had my dad run to town to grap me a new fuel pump and fuel filter for the quadrajet (inlet). Track ran great for 18 more miles then did the same darn thing.
Any idea what would be causing this? Sending unit?
dremmick is offline   Reply With Quote
Old 04-15-2014, 02:45 PM   #2
cdowns
cdowns's Avatar
Re: Fuel issue?
could be a clogged fuel sock in the tank
or it could also b a bad gas cap that is not letting the tank vent
Old 04-15-2014, 02:51 PM   #3
engineer_gregh
engineer_gregh's Avatar
Re: Fuel issue?
I experienced the same thing with my truck when I first bought it. It had not been driven for quite some time. First thing I found was that someone had put a fuel filter underneath the truck close to the gas tank. It was completely clogged. Long story short, I replaced the tank, sending unit (came with new sock), and blew out the lines. Not good for gas to sit up for years in the tanks of these trucks.
engineer_gregh is offline   Reply With Quote
Old 04-15-2014, 02:52 PM   #4
67 cst swb
67 cst swb's Avatar
Re: Fuel issue?
Check the small fuel line under the cab, that goes from the tank inside the cab then down the middle of the cab thru the floor to outside the cab and runs down to meet the hard fuel lines under the cab/frame... sometimes this kinks and after sitting, some contaminant may have got lodged in the kinked line. Over time rubber fuel hoses break down and swell closed and/or crack. So it may also be good to check all the rubber hoses.
Also... When you added the fuel filter... did you happen to re-route a fuel line over a hot radiator hose or is it laying on the motor? If so, this could be causing a vapor-lock situation
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-15-2014, 02:54 PM   #5
dremmick
Re: Fuel issue?
thats where I put the fuel filter is right by the gas tank under the cab. Is that a bad location?
Old 04-15-2014, 02:58 PM   #6
engineer_gregh
Re: Fuel issue?
I put my filter between the fuel pump and carb. I don't want to crawl under the truck every time I need to change the filter. Also in the beginning I used a see through plastic filter so I could see if fuel was actually being pumped to the carb. I'm making a very frustrating and time consuming problem seem like I fixed it overnight. That was not the case. It drove me nuts for weeks before I finally ended up replacing the tank.
Old 04-15-2014, 03:00 PM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Fuel issue?
Sounds like the problem with my truck, it causes me some issues. It just cuts off, but then can be started back up
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-15-2014, 03:14 PM   #8
dremmick
Re: Fuel issue?
did you ever fix your problem? What have you replaced?
Old 04-15-2014, 03:19 PM   #9
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Fuel issue?
Well I am using a Boat Plastic gas tank, turned out my fuel filter was beyond clogged, and so was my Air filter.. Haven't been able to test it out due to my inline fuel filters leak. Not to mention its raining currently in my town.. I'll see if it fixes.. Was yours backfiring through exhaust and bogging down when put in gear?
I've replaced
Fuel Filter
Spark Plugs
Plug Wires
Rotor Cap
Distributor Cap
Coil
Thermostat
1971 GMC Sierra
1959 GMC 100
Old 04-15-2014, 03:25 PM   #10
dremmick
Re: Fuel issue?
It was bogging down only at higher sepeed 65+ mph. when it started to bog you could mash the throttle and nothing would happen. It did back fire also.
Old 04-15-2014, 03:28 PM   #11
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Fuel issue?
Probably another more knowledgeable member will tell you
Mine bogged down if I wanted to knock it into gear, although I have had the Carb rebuilt
1971 GMC Sierra
1959 GMC 100
Old 04-15-2014, 07:21 PM   #12
geezer#99
geezer#99's Avatar
Re: Fuel issue?
9 times out of 10 a bog is caused by a lack of initial timing.
geezer#99 is online now   Reply With Quote
Old 04-16-2014, 10:05 AM   #13
dremmick
Re: Fuel issue?
but the bog is not constant. It only happens hafter driving 10-20 miles
Old 04-16-2014, 10:44 AM   #14
geezer#99
geezer#99's Avatar
Re: Fuel issue?
What distributor you got?
Old 04-16-2014, 10:57 AM   #15
67 cst swb
67 cst swb's Avatar
Re: Fuel issue?
Well... Im not sure your fuel filter location is the problem. But that's not where I would put it. Seems to me that could possibly cause the fuel issue.
I would eliminate that fuel filter from anywhere between the fuel tank and the fuel pump.
Let me try to explain my thought on this...
Think of yourself drinking from a large cup of soda through a straw... seems pretty easy right? Now... think of that straw having a large bulb shaped bulge in the middle of it. It will take more sucking pressure to pull that soda up the straw to fill that bulbous bulged area before it can continue up the straw...
So, My mind tells me... your fuel pump is having to "pressurize" the fuel filter before it can siphon the fuel from the tank. That just may be too much for the fuel pump to do under load and/or for a longer duration of time. I think with that air pocket/cavity (that is the fuel filter itself) in the fuel line, its just not able to keep up with the volume needed.
Now... if the fuel system was a gravity fed system, as is... fuel was supplied out of the bottom of the tank and gravity was constantly able to supply fuel to the line coming off the tank... then I would be ok with a fuel filter there. But these tanks have a tube running from the top of the tank (with a tube inside that runs to the bottom...like a straw) So, essentially the fuel pump has to siphon the fuel from the tank.
I could be wrong in my thinking... but, I still would not put a filter between the in-cab tank and the fuel pump.
Also... a diaphragm style fuel pump (like the ones on our trucks) doesn't care how dirty the fuel is, it would pump mud if it were runny enough. The carb is what can't handle the dirt/contaminants in the fuel. I would move the fuel filter to a location between the fuel pump and the carb.
What can it hurt... move that filter to a location after the fuel pump and see if it fixes the problem...
My Trucks:
Old 04-16-2014, 11:48 AM   #16
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Fuel issue?
Try what '67 said, sounds like an issue that needs to be resolved
1971 GMC Sierra
1959 GMC 100
Old 04-16-2014, 12:31 PM   #17
engineer_gregh
Re: Fuel issue?
Based on hard lessons learned. The rusty tank needs to be replaced and the clean looking one was replaced almost two years ago. I run ethanol treatment with every tank of gas. Take a look inside the neck of your tank and the inside rim of your gas cap, how does your's look?
Old 04-16-2014, 01:42 PM   #18
dremmick
Re: Fuel issue?
I will try what 67 said. Im using a stock Delco HEI distributor.
Old 04-16-2014, 01:52 PM   #19
imjeff
imjeff's Avatar
Re: Fuel issue?
Definitely try what 67 said. Filters are problematic on the suction side of the pump. It creates a low pressure area between the filter and the fuel pump area which reduces the boiling temp and can create vapor lock issues without much heat. Don't buy into any of the magic treatments for E10 gasoline. Nothing will prevent ethanol from absorbing water and phasing out other than using enough that it doesn't get a chance and minimizing air space in your tank.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-16-2014, 02:06 PM   #20
geezer#99
geezer#99's Avatar
Re: Fuel issue?
Hei eh!!
What you're describing is related to a failing module.
They start to quit once they get heated up. Heat can sometimes be caused by low voltage.
If you don't have 12 volts to the hei the module will overheat.
Do you have a dedicated 12 volt wire for your hei?
Read about an hei module here.
http://www.crankshaftcoalition.com/w...EI_distributor
Old 04-16-2014, 03:22 PM   #21
CUSTOM/10
CUSTOM/10's Avatar
Re: Fuel issue?
I had the same issue with my old 72. Mine turned out to be the pick-up sock in the tank. Or should I say the rag that the PO rapped around the sock with a rock in it. The sock was ripped and the threads from the rag were getting sucked up into the tube partly blocking it. Running around town slow it was fine, get out on the highway the motor would starve for fuel, bog and die. Took me a bit to find that one. Before finding that I always wondered what was in the gas tank rolling around when i took a corner. ( The Rock ) "LOL"
Gary
Check the sock if nothing else works !!!
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-16-2014, 10:32 PM   #22
engineer_gregh
Re: Fuel issue?
"Don't buy into any of the magic treatments for E10 gasoline. Nothing will prevent ethanol from absorbing water and phasing out other than using enough that it doesn't get a chance and minimizing air space in your tank."
We all have a right to our opinions. Based on two years of using Sta-Bil Marine treatment in every tank of gas the pictures I posted back up the fact there is Zero rust in the tank. Believe what you like, as for me I'll continue to use it.
Old 04-16-2014, 11:08 PM   #23
imjeff
imjeff's Avatar
Re: Fuel issue?
If I was expressing an opinion versus a well researched fact, I would have made that clear. Phase out has nothing to do with rust. I don't use any additives and I don't have rust in my tank either. That proves nothing. Phase out happens when water, in the form of humidity or condensation, is absorbed by the methanol causing it to leave the gasoline and become a separate mixture. Since ethanol is used to raise octane, phase out lowers your octane causing more problems. No amount of additives will prevent this chemical process from happening. That's why refineries mix ethanol into the gas while it's being loaded into trucks going out to deliver. The best defense against this problem? Keep your tank full and don't let it sit for long periods of time. Science isn't really debatable. A little research will reveal exactly what I said about phase out. It's been studied...even your favorite. IMO, if you base an additive's success on whether you have rust in your tank, you're wasting a lot of cash. For my small engines and when I put an old vehicle away for awhile, I use clear gas and plain old Stabil. It does keep plain gas usable longer. As you said, believe what you want. Doesn't cost me a dime.
Jeff
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 04-16-2014, 11:30 PM   #24
engineer_gregh
Re: Fuel issue?
Jeff, I don't know about Tacoma but in Nashville if you don't use ethanol treatment you will have rust in your tank. I've not used anything but Sta-Bil so I can't comment on any other treatments. I own and drive 2 71's and 1 72. Since replacing the tanks and using Sta-Bil, no more rust.
Old 04-16-2014, 11:40 PM   #25
imjeff
imjeff's Avatar
Re: Fuel issue?
Alcohol is a hygroscopic solvent. It absorbs water and cleans. The rust problem has to do with water, not alcohol. I own and drive classics every day as well. That doesn't change the laws of physics.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
