Old 04-16-2014, 06:42 PM   #1
ChevyFreak60
ChevyFreak60's Avatar
Trailing arm spring bolt.
Hey dudes I am wondering if ya'll know how to remove the bolt that holds down the spring retainer to the spring on a trailing arm. I was replacing the rear springs on my truck this past weekend and I broke the one on the drivers side. Luckily I can bolt it to the top frame for now. Any info and pics are greatly appreciated....
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 04-16-2014, 08:47 PM   #2
PGSigns
PGSigns's Avatar
Re: Trailing arm spring bolt.
Most of the time these are just rusted in the trailing arm. When I did mine I had to hit it with the air hammer to break it loose from the trailing arm. Then replaced it with a new bolt.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-16-2014, 08:51 PM   #3
ChevyFreak60
Thank you for the info. Where cani buy a replacement bolt?
Old 04-16-2014, 09:36 PM   #4
rickywideglide
rickywideglide's Avatar
just had mine all apart,broke all bolts holding spring retainers. i ended up getting some bolts from lowes for the time being
rickywideglide is offline   Reply With Quote
Old 04-16-2014, 10:07 PM   #5
cortcomp
cortcomp's Avatar
I did the same, lowes grade 8 bolt. Both mine holding the upper were broke.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 04-16-2014, 10:10 PM   #6
ChevyFreak60
Do ya'll know what size bolt it is?
Old 04-16-2014, 10:41 PM   #7
rickywideglide
1/2 x 13 x 5 1/2, you could probably get away with 5 inches though
Old 04-17-2014, 07:48 AM   #8
firemanjimtfd
firemanjimtfd's Avatar
Classic sells the complete bolt kit with new plates. I just installed in mine.
firemanjimtfd is offline   Reply With Quote
Old 04-17-2014, 10:42 AM   #9
ChevyFreak60
Thanks for the info guys...
