Old 04-16-2014, 11:32 PM   #1
TwoFiftyShifter
Axle Swap or no?
Got an 84 K10 and my rear axle broke. The ring, pinion, carrier, everything. I have been on the lookout for a replacement, but it has been tough. The truck has 3.08 gears, and has a 305 with a SM465 4 speed.
Instead of finding another 3.08 rear to swap in, which I can probably find during the spring, I found an interesting truck for sale. a 79 K30, with just a frame, cab, tranny t-case and axles. Guy will deliver it for $500 total. The truck was a town truck way back when.
Could that work? I would like stronger axles, but would also like a deeper gear ratio. What do you all think?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 04-17-2014, 12:04 AM   #2
83GMCK2500
Re: Axle Swap or no?
K30 spring perch is narrower than yours. Two options: One: cut perches off, move out, re-weld them. Two: knock rivets out of both truck's rear leaf spring brackets, bolt the K30 rear, leaves, and brackets onto your truck. If donor truck is same wheelbase as yours, you should be able to use it's drivelines, otherwise you will need conversion ujoints.
Front axle bolts in.
You're getting a K30 rolling frame for $500? Delivered? BUY IT! Around here that Dana 60 front can still fetch $750-$1,000 alone.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-17-2014, 12:45 AM   #3
willett
Another Day, Another Dollar
willett's Avatar
Stick everything on the 1 ton frame and you will have a much more robust truck! That's a steal of a deal!!!!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-17-2014, 01:02 AM   #4
Cabnchassis
I agree. Don't swap the axle swap the truck. The K30 is going to have a lower gear ratio, what engine did it have? If it was a big block or a detroit it will most likely have 4.10s or something close to that.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 04-17-2014, 05:30 AM   #5
andrewmp6
If the k30 is worth building go for it if not take both axles maybe the t case of its a np205.
