Old 04-18-2014, 01:16 PM   #1
1963chevyc20
1963chevyc20's Avatar
another floor pan question.
are all floors the same from 1960-66. i am looking to buy an entire floor plan for my old 63. the crusher and salvage yard in my town only has 64 and up. will the floors work?
1963chevyc20 is offline   Reply With Quote
Old 04-18-2014, 01:32 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: another floor pan question.
I'm not a floor pan expert, but from what I've read the 60-62 has different body mount locations than the 63-66. Also there is a high hump floor and a low hump floor. They are distinctively different. The high hump has a removable pan that almost has square sides and is flat across the top. To my knowledge all high hump pans are removable.
Low hump floors drop down in front of the seat. Some have removable pans while other are one piece with the floor.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-18-2014, 01:44 PM   #3
1963chevyc20
So do they look the same tho? Idf I pull floors out of a 64,65,or66 1 will they bolt up the same or in other words will they fit. And 2 will they look the same as the floors in my 63?
Old 04-18-2014, 02:25 PM   #4
Casaba
Won't bolt up without mods. The mounts for the frame are different. 60-62 used an X frame.
Go check out LMCtruck and look at floor patch panels and you will see what I mean
Casaba is offline   Reply With Quote
Old 04-18-2014, 03:09 PM   #5
padresag
why do you want to replace the complete floor pan,that is a major job. they are not bolted in , but spot welded in,
ron
padresag is offline   Reply With Quote
