04-20-2014, 09:22 PM | #1 |
manual trannys
planning on swapping out my 4sp with a nv4500 5sp
Open to ideas and info Thanks |
04-20-2014, 10:08 PM | #2 |
The Older Generation
Re: manual trannys
If you want some quick reading type NV4500 into the Google search box at the top of this page, click on the circle in front of "67-72chevytrucks.com" and click on the Google button. LockDoc
04-21-2014, 09:09 PM | #3 |
Re: manual trannys
thanks, Already checked out the archives.
Was looking for opinions on whats being used out there. The nv4500 looks a little tall to fit. I do not have a high hump floor pan |
04-21-2014, 10:12 PM | #4 |
Re: manual trannys
The NV4500 is a heavy duty truck trans. If your looking for something for your 1/2 ton step side might look up the T5 or T56 6-speed.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
04-22-2014, 08:00 AM | #5 |
Watch out for your cornhole !
Re: manual trannys
For a half ton, I'd do an NV3500 instead. Smaller, lighter, and overdrive. Able to hold up to modest powerplants.
04-22-2014, 12:22 PM | #6 |
Re: manual trannys
If you're considering the expense of installing a 5 or 6 speed, I would think buying a high hump floor would be the least of the expenses involved.
