how to install this?
i purchased my 2 ton wench for my 63 c20 and i would like to put it on my front bumper. do i need a grill guard? i don't know where to look for one of those if i need one.
Re: how to install this?
post up a pic of the winch. maybe post this in the 4x4 section
1961 chevy K10 my build is------------61K10 build |
ok.
![]() Join Date: Jan 2011
I would build a receiver hitch setup that bolts to the front frame rails and set it up on a hitch plate. That way when you don't need it, it is out the weather and you can keep the look of the truck intact. No matter what you choose to do it will be a custom build.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#5 | |
x2 I had a neighbor who was into 4 wheeling and had a 79 toyota pu he wheeled with. He mounted two receiver hitches to his truck, one front and on rear. then mounted his winch to a "receiver hitch winch mount" like this http://www.autoaccessoriesgarage.com...er-Winch-Mount Then when not in use it sat in the tool box in the bed or in the garage. When needed he would just connect it on which ever end of the truck it was needed. I always thought that this was a super idea myself. |
#6 | |
![]() Join Date: Aug 2004
I agree with these two fellows.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Man, that wench is huge if she is 2 tons!!!
Chevy addict
Yup, you'll have to custom build a mount.
2 ton or 4,000 pound winch isn't much, minimum capacity to get you out of anything would be an 8,000 winch. |
Yea. I have given up on it for now. Yes the wench is very big! I need it tho. I pull trailers with a lot f weight on em. Was pulling in the drive while it was raining and I had my dump trailer full of trees and my truck is 2wd. She sunk and got stuck. Had to flag down a 4x4 to pull me out. Wish my k20 was running. 1974 k20 with a 75 grill.
![]() Join Date: Mar 2011
I don't know if you could strap a wench that size on the front of your truck.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
