Old 04-28-2014, 11:30 PM   #1
JayPeee
Front Suspension Question
When I bought my '61 GMC, it was already converted to disc brakes so it now has a coil spring suspension. I want to get drop spindles and replace the control arms. My question is, how can I tell what was used for the conversion? I want to be sure I order the correct control arms and spindles or does it not matter?
JayPeee is offline   Reply With Quote
Old 04-29-2014, 01:36 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Front Suspension Question
Did you take a look around in the Suspension sub forum or look at the Drum-to-Disc Upgrade FAQ? The upgrade FAQ has breakdowns of the normal procedure, and what parts are usually used.
That should show you the combo's and how to identify what you have. More than likely, the front suspension, or possibly the whole from crossmember was taken off of a 71-87. The exact combination of parts may take a second to piece together.
An easy starting point for references is to look at; does the a-arm have metal or rubber bushings, what bolt pattern are the brakes and are they on a 1" or 1.25" thick rotor, power steering? There's more than that, but those are places to start to work off of with the info in the thread posted.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2014, 08:39 PM   #3
JayPeee
Thanks for that...not sure how I missed that.
OK so working backwards given that I don't know what crossmember I have, I do know that the previous owner did a 6 lug drum to disc conversion. The FAQ says that ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version**.
Based on that, does that mean from the spindles working backwards to what connects to it (ball joints, tie rods, etc.) are all from 73-87?
Here are pics I snapped up
Old 05-04-2014, 12:27 AM   #4
Captainfab
60-66 Nut
The upper and lower control arms are typical of a '63-'72 C10. You obviously have either cut springs or dropped springs.......the lower bump stop is touching so you don't have much suspension travel. From what I can see in the pics it looks like you may have '71-'72 spindles and dust shields. The pic is a little blurry. As far as I know the aftermarket 6 lug rotors will fit the '71-'87 spindles as long as they are designed for the 1.25" thick HD rotors
Old 04-29-2014, 01:37 AM   #5
Captainfab
60-66 Nut
If you could post some pics of the dust shields on the back of the rotors and the control arm bushings, we should be able to give you an idea of what you have.
