04-29-2014, 11:07 AM | #1 |
Standard wheel arch height on a '66 Short Fleet?
Some great stance and lowering on various builds.
I have a '66 Short Fleetside which has been lowered with heated cools etc a long time ago. THREAD HERE: http://67-72chevytrucks.com/vboard/s...d.php?t=585901 The truck behaves like a rubber duck on water when doing the bends. It is fitted with a 350/3 speed auto combo that obviously influences ride height a bit. But hope someone can measure a "standard height" V8 truck to give me a better idea of where I should be and where I should be heading. I really like a bit of nose down rake. Plans are to keep to standard 6 lug, drum brake setup so no dropped spindles etc. And is still needs to to my teardrop. I am looking at replacing the shocks and springs when I repaint and strip down the truck. Brothers currently has 50% off on the lot. My truck parked up in the garage shows these measurements to the underside of the fenders. Front 27 1/4 Rear 26 1/2 on passenger side 26 on driver side Does anyone have the stock standard measurements for these truck front and rear please??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-29-2014, 11:55 AM | #2 |
Re: Standard wheel arch height on a '66 Short Fleet?
Hey Grizz, just order stock front and rear coils.......that should get you back to stock height.......and stock shocks....................its a no brainer....Kieth
04-29-2014, 02:28 PM | #3 |
Measurements from the factory would depend on rim and tire size that were installed on the truck.
I agree with Keith, if you want stock height/stance just order stock springs/shocks.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-29-2014, 03:59 PM | #4 | ||
I want it as it stands or even a touch lower. But need an idea on original height so that I know where I am now and where to head.
04-29-2014, 04:32 PM | #5 |
It seams like someone on here from the most original trucks in existence thread could give you that measurement but instead I will try to help.
on a fleet side truck measuring from the bottom of the fender to the center of the hub. A 5 inch rear drop will equal 10.5 inches and in the front a 4.5 inch drop will equal 14 inches. I know this is not exactly what you wanted but hopefully it will help you calculate. |
04-29-2014, 04:42 PM | #6 |
My truck is stock stance, but I'm running a 235/75R15 which is a little taller than the factory tire. I believe a 215 would be pretty close to stock tire...I can get numbers off either my fleet or stepside. Both are stock height and run the same tires size.
