04-30-2014, 01:46 PM | #1 |
68 c20 cst?
Trying to figure out what I am working with... Been doing some research and I am stuck... The only thing I can think of is that I have a CST?
The truck has a 350w/ TH400 trans and has power breaks and steering... I have not found any info that the 68 was made with a 350 although it looks like it is all stock... the title says 68 so that rules out the possibility of a year lost? Help me out here.. THANKS GUYS! |
04-30-2014, 02:06 PM | #2 |
Re: 68 c20 cst?
The front end of that truck is 69 or 70, so if it's really a 68 the front end has been swapped. It would stand to reason then that the motor and transmission could have been swapped out as well.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
04-30-2014, 02:41 PM | #3 |
Re: 68 c20 cst?
What makes it a 69-70 front end? Trying to tell the difference...
04-30-2014, 03:08 PM | #4 |
Re: 68 c20 cst?
The grill has a bar with CHEVROLET lettering between the headlights on the 69-70.
It looks like all the other trim was from 69-up too so my guess is the DMV processed the title in 1968 on a 69 model year truck. |
04-30-2014, 03:04 PM | #5 |
...just another truck junkie..
Re: 68 c20 cst?
The whole grille and hood. That style was only in '69 and '70. The grille style on the '68 was used in '67 and '68. So, if the VIN translates to '68 then that front has been swapped. As far as I know, a '68 pickup did not have a 350 option, so that engine is out of something else.
Mike "Bear" Shea |
04-30-2014, 03:11 PM | #6 |
Re: 68 c20 cst?
Your truck appears to be a 1969. Probably a early build that got titled as a 68. You can check your vin number to determine for sure.
04-30-2014, 03:15 PM | #7 |
Re: 68 c20 cst?
67-68 moulding were also different than the 69-72 so if the truck did happen to be a 68 witch is looking doubtful at this moment all of the other sheet metal has been changed as well. Jim
04-30-2014, 03:21 PM | #8 |
Re: 68 c20 cst?
Yeah the VIN reads as CE248Z171828 So per the decryptor it should be a 68? So is it just the grill or do the fenders and hood need to be reconverted for restore? And what engine was stock in the 50th anniversary truck? It has been repainted and I have noticed that it was registered to the Forrest service if that helps anything? Is the TH400 anything special? Thanks again for all the input!
04-30-2014, 03:25 PM | #9 |
Re: 68 c20 cst?
That upper fender molding doesn't even look like something off of any vehicle of that vintage. You sir, have bought a Canardly... You canardly tell what the heck it is!! I'd say forget the resto, do what you want with it. You have a great engine combo. Just make it nice.
05-13-2014, 03:57 PM | #10 |
Vintage 4x4s
Re: 68 c20 cst?
It is stock 69 to 72 trim on conventional 2 tones and some solid color trucks.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
04-30-2014, 03:31 PM | #11 |
Re: 68 c20 cst?
Here is another look at that front end
04-30-2014, 03:53 PM | #12 |
member #16
Re: 68 c20 cst?
Which emergency brake do you have? The 67-68 has a hand pull and the 69-70 has a foot pedal.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-30-2014, 03:57 PM | #13 |
Re: 68 c20 cst?
It is a hand pull brake..
04-30-2014, 04:25 PM | #14 |
member #16
Re: 68 c20 cst?
Here is a pic of a 67-68 grill. To change you will need the fenders, hood, grill and radiator support. Your bumper is the same. The custom badge on the door looks correct for a 68. A CST would have a CST badge on the door.The 350 eng. was from 69 and later in trucks. The TH400 was available in 68.
04-30-2014, 04:43 PM | #15 |
Re: 68 c20 cst?
Bowcoffin, Can you check your frame VIN, It's a partial.
04-30-2014, 04:35 PM | #16 |
Re: 68 c20 cst?
Thanks John, Appreciate it! Looks like this is going to get spendy!
04-30-2014, 04:44 PM | #17 |
Re: 68 c20 cst?
I can check it Monday and let you know.. what are you thinking with that?
04-30-2014, 04:46 PM | #18 |
Re: 68 c20 cst?
To see if the cab is original to the frame.
04-30-2014, 04:48 PM | #19 |
member #16
Re: 68 c20 cst?
Your partial frame number should have a 8Z for fremont plant and yr. model and the last no's of your VIN.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 04-30-2014 at 04:54 PM. |
04-30-2014, 04:53 PM | #20 |
Re: 68 c20 cst?
EDIT: John got it, Z8xxxxxx
04-30-2014, 04:48 PM | #21 |
Re: 68 c20 cst?
Oh I see... Last weekend I was doing some work with the frame (Scraping it down for paint) and noticed that the rear bumper was "Jimmy Rigged' on with a weld job. Looking at the actual frame, it looks really short to be a C20, was thinking it looked more like a C10, rigged for a C20? Ill post more pics
04-30-2014, 04:50 PM | #22 |
Re: 68 c20 cst?
Check these out.. the black frame obviously is after all of the bumper and excess has been taken off.. like I said before it was registered to the forest service so I'm not sure if they had it altered... it was a pain to cut the weld though...
04-30-2014, 04:56 PM | #23 |
Re: 68 c20 cst?
Sounds good.. I'll check and let you know... If it's not matching- I'm pretty much screwed as far as saving any sort of a restore goes huh?
04-30-2014, 05:03 PM | #24 |
Re: 68 c20 cst?
Here is my bet. It is a rebuilt wreck from back in the day, I know I have been doing it thirty years and was not the one that came up with the idea fresh by any means. I still say it has had a sheet metal change, that is how the upper and lower moulding are off the later model than the 68 mouldings. It makes perfect sense to me, but maybe just me. Jim
04-30-2014, 05:17 PM | #25 |
The Older Generation
Re: 68 c20 cst?
How about a picture of the ignition switch also.... LockDoc
