Old 05-04-2014, 02:40 PM   #1
Corts60
Just here to tinker
Corts60's Avatar
Found two build sheets under my seat…help Keith Seymore
So I just bought a 54k mile '78 Silverado and I found the build sheet under the seat. I was so excited! But then I found a second one, that was for a completely different truck. What's the deal?
This one is for my truck:
This one is for a 1978 GMC Jimmy with a 400:
Old 05-04-2014, 03:37 PM   #2
mrolds88
Re: Found two build sheets under my seat…help Keith Seymore
On occasion these things happen. I got a 64 olds that had a build sheet from another car and not the right one for it. But from the looks of things, you got a build sheet for a K5 Jimmy that was white and a red interior. Would be cool to find the owner of that one.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-04-2014, 04:53 PM   #3
mgchevyparts
mgchevyparts's Avatar
usually the next one in line
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 05-04-2014, 06:45 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
That would make sense. I don't know how to read these things so hopefully someone can chime in and let us know how that assembly line works….
Old 05-04-2014, 08:36 PM   #5
80SPORT
80SPORT's Avatar
One of my duallys (1980) had a blazer build sheet under the seat as well as the one for the truck.
Yours has a couple of interesting options...the PA6 wheels and ZY5 2 tone.
Not sure what the D88 sport stripe is unless it is the hood stripes??
80SPORT is offline   Reply With Quote
Old 05-04-2014, 09:53 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
I think it is for the hood stripes as well.
Old 05-04-2014, 08:32 PM   #7
Axle
Axle's Avatar
Technically, they are considered garbage after use. Some big shot may have been walking the line at that station so the guy pulls the sheet, and tosses it in the next car down the line when 'the coast is clear'. Or any other number of reasons the sheet ended up in someones hand and then chucked in the next convienient car down the line.
Alex.
Axle is offline   Reply With Quote
Old 05-04-2014, 10:23 PM   #8
Keith Seymore
Keith Seymore's Avatar
I am happy to answer any specific questions you might have.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-05-2014, 10:40 AM   #9
Axle
Axle's Avatar
Did GM sequentially assign vins as they went/go down the line?
At the local ford plant, the vins are not sequential, but a "lottery" of sorts where the vin is assigned ahead of time and has no bearing on assembly sequence.
Alex.
Old 05-05-2014, 11:31 AM   #10
Keith Seymore
Alex.
Basically, no.
For us it varies by assembly plant.
Some plants assign the VIN early in the process and build straight through. Those are in the minority.
Most plants have a "bank"/accumulator after the body shop and then again after paint, with multiple "lanes" to input vehicles and draw vehicles from. There is no "first in/first out" relationship. That gives two opportunities to shuffle jobs prior to pulling them for final assembly, based on work load balance, part availabililty, extended repair etc.
Additionally - there are often separate VIN sequences for nameplate (Chevy vs GMC, or Pontiac/Buick/Olds) and sometimes even engine type (V8 starts at 100001 but 6 cylinder starts at 600001). So - based on these constraints the VIN sequence can be dramatically different for two vehicles following each other down the line, as shown here.
K
1979-1986
1986 - 2019
