Old 05-07-2014, 09:58 AM   #1
Houston Ben
Houston Ben's Avatar
Brake booster, bracket and AC removal
Is there anything special to removing the brake booster and bracket and AC off the firewall?? I have a couple of rust holes that need taken care of but not sure on how to go about doing it.
Houston Ben is offline   Reply With Quote
Old 05-07-2014, 06:22 PM   #2
Dead Parrot
Re: Brake booster, bracket and AC removal
From memory on the brake booster: Undo the push rod from the brake pedal under the dash, disconnect the brake lines(brake fluid makes good paint remover), disconnect the vacuum hose, remove the 4 nuts holding the booster to the firewall, avoid smashing hand when removing last nut.
Haven't removed the engine side AC stuff.
Dead Parrot is offline   Reply With Quote
