user # 2756
![]() Join Date: Jun 2001
Swap in a 465/205
I am going to swap a SM465/NP205 combo from a 71 for my 700R4/NP208 in my 1986 K5. A previous owner installed the current motor a 350 for the stock 305. I have not run the numbers, but I think the 350 is an earlier 2-piece rear seal 350. So, help me run down my list of parts:
I have the 71 flywheel/clutch/pressure plate and the clutch fork I need the clutch pedal assembly and will need to modify the tranny hump. In 1986 what type of clutch setup did it have? mechanical linkage or hydraulic? Will the 71 bell housing work with the newer clutch linkage? or will I need to source a new one? I could probably scour many sources for info but then I wouldn't get to talk with you all. Thanks!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
user # 2756
Re: Swap in a 465/205
Looks like it will be a hydraulic set-up.
![]() Join Date: Aug 2008
In 71 they used a mechanical clutch setup with a bell crank or z bar. In 86 they used a hydraulic clutch. Hydraulic is better (in my opinion) than mechanical. However you'll either need a different bellhousing or you'll need to buy a slave cylinder bracket made by advance adapters or fabricate your own bracket. You'll also want to find the factory clutch pedal assembly for an 85-87 pickup and bolt it in.
Why are you making the swap?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
user # 2756
I prefer the 4 speed over the 700R4/208. I'm going to look at advanced adapters. Thanks.
The SM465/NP205 combo is a hell of a lot stronger than the weak-sister 700R4/NP208.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
I put a 1975 465/205 in my 87 2 to 4 wheel drive build with early 80's mechanical clutch setup http://www.67-72chevytrucks.com/vboa...d.php?t=576936
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
#7 | |
user # 2756
You dont need to change the floor to a bolt out or anything. I put a 79 2wd auto cab on a 4x4 chasis with the 465 trans. All I did was cut the hole for the shifter. Having the bolt out floor pan does make pulling/installing the trans alot easier though. I prefer the mechanical clutch personally as you have alot more feel of clutch engaugement. The only factory hyd clutch I liked was from a 60 chevy pickup. It was adjustable so pedal hieght could be adjusted to your liking.
#9 | |
