Old 05-10-2014, 09:25 AM   #1
donthekawguy
donthekawguy's Avatar
sway bar ?
While I was at the wrecking yard the other day, I was pulling the rotors off of a 75 for my truck and noticed there was a front sway bar on the truck. Would that bar work on my 66? I should have pulled it but by the time I got what I needed I was grumpy and hot so I left it. I did notice it bolts to brackets that hang down from the frame and then to the lower control arms. I'll have to check my frame for the same mounts. Not sure if the 75 has the mounts welded or bolted to the frame.
66 shorty
donthekawguy is offline   Reply With Quote
Old 05-10-2014, 09:42 AM   #2
morethanstock66
morethanstock66's Avatar
Re: sway bar ?
You may have to drill holes in the lower a arms to mount it, but it should work barring previous damage. Check for heavy rust and make sure it is straight. Last thing you want is to mess up alignment due to bent sway bars
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 05-10-2014, 11:06 AM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Re: sway bar ?
There is good info abou this in the FAQ section
DPowers is offline   Reply With Quote
Old 05-10-2014, 11:09 AM   #4
donthekawguy
Re: sway bar ?
My arms already have the holes which is a good thing. The truck wasn't wrecked I guess it just gave up so the scrapped it. It looked really clean on the underside. I just need to find out how it bolts to the frame now. On the 75 it has a bracket that is either welded or bolted onto the bottom of the frame the the bar mounts to. My truck doesn't have that bracket and I don't know if I even need it. I'll have to go back next week and check it out.
66 shorty
Old 05-10-2014, 12:12 PM   #5
donthekawguy
Re: sway bar ?
OK got it figured out. Had to dig around in the search section for a couple hours but found the thread. I needed the lowered truck brackets. ECE wants $19 for the brackets and $19 for shipping! I went to classicperform.com and got them for $23 with shipping. Now I just need to go get the bar and find bushings. My truck is going to handle like a Vette!
66 shorty
Old 05-10-2014, 12:56 PM   #6
Woogeroo
Question Re: sway bar ?
a couple of hours?
ya coulda just went in the FAQ as someone suggested(up top in your own thread here) to the suspension section... more than one thread there with sway bar information.
Well, we can lead a horse to water...
-W
Woogeroo is offline   Reply With Quote
Old 05-10-2014, 01:53 PM   #7
bama63
bama63's Avatar
Re: sway bar ?
Sorry - no matches. Please try some different terms. in donthekawguys defense thats pretty much all i can ever find searching the FAQs
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 05-10-2014, 06:40 PM   #8
donthekawguy
Re: sway bar ?
Thats what I kept getting but finally found a thread that had all the info. I aint smart but I am persistant.
66 shorty
Old 05-11-2014, 12:34 AM   #9
Woogeroo
Wink Re: sway bar ?
Well, you are either doing it all wrong or not reading, cuz there are 7 separate front sway bar threads listed in the 60-66 FAQ in the suspension area... and no searching is needed.
-W
Old 05-10-2014, 09:37 PM   #10
DPowers
DPowers's Avatar
Re: sway bar ?
Here is links to two very good threads about swaybars:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
http://67-72chevytrucks.com/vboard/s...d.php?t=517255
When using FAQs you dont really have to do a search.
Go to forums>1960-1966 Message Board>60-66 FAQ Index and then scrollaway until you find the blue link. Hope that helps.
We want pics after install.
Old 05-10-2014, 11:13 PM   #11
Softpatch
Softpatch's Avatar
Re: sway bar ?
** My truck is going to handle like a Vette!**
Well Not quite like a vette But it is a very good upgrade
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 05-11-2014, 08:30 AM   #12
donthekawguy
Re: sway bar ?
Those are the mounts I ordered. I got them at CPP. I'll take pics for sure. I should be getting my LCA's Mon. or Tues. from powdercoaters and start putting this thing back together.
66 shorty
Old 05-11-2014, 10:55 AM   #13
RockTonka
RockTonka's Avatar
Re: sway bar ?
We just grabbed a mid 80's 1 ton dually Chevy swaybar and all brackets out of the junkyard, trimmed the brackets bit and welded them in where they fit best on the frame, LCA brackets were a bolt on...$20 for the bar and less for new bushings
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-11-2014, 08:25 AM   #14
donthekawguy
Re: sway bar ?
I shoulda went to the suspension area. I was just going to the FAQ at the top of the page.
66 shorty
Old 05-11-2014, 03:30 PM   #15
DPowers
DPowers's Avatar
Re: sway bar ?
I did the install awhile back and can definetly tell the difference.
