07-31-2003, 10:28 AM | #1 |
fuel
changing wheel bolt pattern
hey i was wondering if there was anyway to change a 4x3/4 bolt pattern to a 5x5 for our trucks, i have a set of vette wheels that i would like to use on the 72'
08-01-2003, 09:11 AM | #2 |
I think there are wheel adapters on the market, but I wouldn't use them. You could have the hub and rear axle's lugs removed, holes welded and redrilled to 5" BC and install new lugs. I think those are the only two options you have .
08-01-2003, 03:18 PM | #3 |
Adapters come in high & low quality. Billet adapters are much better than the old cast style, so they're a good alternative.
I re-drilled my front rotors to a 5x4.75 car pattern (adapters would have added to my backspace which I didn't want), but because of backspacing requirements I did use billet adapters for the back. It was about $75 for the machining on the rotors & $165 for the adapters. Remember, if/when you opt to re-drill . . ..... if you have to replace the drums @ any point, you have to get them re-drilled as well. With adapters you won't have to. You can see pics of my truck w/the car wheels on the 78-87 board. Look for the heatwave pics post pg1 & 2.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-01-2003 at 03:21 PM. |
08-01-2003, 03:58 PM | #4 |
fuel
sorry im kinda slow, did you weld the wholes shut on the drums and the rotors and then redrill them, was heat a problem when you welded them? also will any shop redrill them or what kind of shop do i look for? and your truck is sahweeeeet, i love that color, i wouldnt change a thing!!!!! thanks alot for the help!
08-01-2003, 04:01 PM | #5 |
fuel
ya im really slow, i just re-read your post and saw that you used the adapters for the rear, sorry, where did you get them??? will they hold 527ftlbs of torque???? thanks
08-01-2003, 04:41 PM | #6 |
They're as strong as your stock hub . . .... will it hold 527ft/lbs? They bolt on just like a wheel so strength isn't an issue.
I purchased mine through Skulte Performance (I was under the impression he actually was making them. After I received them, I learned he is just a distributor). Try http://www.motorsport-tech.com/ . This is where mine actually came from. Or do a web search for 'billet wheel adapters'. If you use a 7/8" or 1" spacer/adapter, you will have to get special lug nuts & trim your factory studs slightly. 1.25+" don't require anything special.
08-07-2003, 10:45 PM | #7 |
Following the same line of question, I have a 69 that I am swapping the front suspension from an 83 pickup or a 78 pickup ( haven't decided wich one) wich are both 5 bolt and my rear will be 6 bolt. Would I be able to get the rear re-drilled to match the bolt pattern??? Then do you know what drums would fit or do I have to re-drill those too???
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
08-07-2003, 11:46 PM | #8 |
You can get re-drilled axles from several aftermarket sources or if you know of a competent machine shop, they could prob do it. My vote would be replacement axles since they're usually stronger & have zero wear @ the bearing races. I got my 5-lug axles for my 68 beater for about $200 from Moser (30% stronger than stock + all new 1/2" studs already pressed in). For the drums, just use 72 & later drums from any auto parts place.
08-07-2003, 11:55 PM | #9 |
Thanks,
my next biggest problem is finding an aftermarket source here in Ontario canada, so I don't have to pay all the extra costs of getting it from the U.S.
08-08-2003, 08:34 AM | #10 |
Don't rule out the machine shop if it's more economical. I originally did my 67 that way & still have those axles/drums in my garage. I changed them to a car 5x4.75 bolt pattern. They welded up the stud holes & re-drilled them, then machined the hub to the correct dimensions, & finally welded/re-drilled the drums. It cost me $200 wayyyyyyyyyyyyy back in 90-91, but I was able to get it done locally.
08-14-2003, 10:37 PM | #11 |
18436572
If you want the old axles redrilled let me know. A guy down here in VA did my 55' panel truck and they were perfect, he's been doing it for about 15 years so he knows his stuff. I think the cost was about a hundred bucks for the axles and brake drums together.
08-20-2003, 01:28 PM | #12 |
A$$ deep into trucks
Hey guys,
Went to look at a project '68 truck about a year ago. The guy was running a "car" 12-bolt out back with the 5X4.75 bolt patern. It had 15X8 'Vette ralleyes all around, so I ask him "What's up in the front?" He told me that he used early-mid '70's CHEVY VAN rotors. They are 5X4.75................IF,IF they are from a G-10 series. Evidently, they share the same bearings/races as the pickups? G-20 series vans (5X5) are most common, but there are a few G-10's still in the yards, and most parts houses still stock new rotors for them. Just a thought! A little yard shopping might save the cost of re-drilling "used" rotors, or new van rotors would be "fresh"!! Mike
hardrock2 |
08-20-2003, 02:36 PM | #13 |
You can get new g10 rotors at autozone for 29.99
08-20-2003, 04:25 PM | #14 |
Keepin an eye out
o.k. im a little confused. I havent had my truck that long. its a '70 and im in the process of changing my rear axles to later 70s 5 bolt and am already thinking of the front disc conversion. What exactly is the bolt patteren on mid 70s 1/2 tons?
08-20-2003, 04:47 PM | #15 |
5 lug on 5" bolt circle...........(5X5; 5 on 5)
'71-'87 disc brake conversion. Mike
hardrock2 |
08-20-2003, 05:28 PM | #16 |
Keepin an eye out
08-31-2003, 03:08 PM | #17 |
yep someof the light duty early 70's 10 series vans used car pattern and 7/16" studs same as lighter RWD cars and s-10s and such like chevelles novas camaros (F and A body) but not the big caprices and oldsmobiles though(B-body)
also 1LE camaro rotors in the 90s were the large 12" diameter and are car small bolt pattern too, at 4.75" but cost a bit more though. but are good conversion pieces Last edited by gmtrucksaddict; 08-31-2003 at 03:10 PM. |
08-31-2003, 03:28 PM | #18 |
gmtruckaddict
ZILLIONS of 67-72 Truck parts?? Hmmmmm!.............No wonder I'm having a hard time finding MORE!! LOL! You must have snatched'em all up! Ha,Ha! Where ya located in this fine state? Mike
hardrock2 |
