05-13-2014, 03:51 PM | #1 |
are 3/4 ton truck frames bigger?
05-13-2014, 04:00 PM | #2 |
Re: are 3/4 ton truck frames bigger?
3200 (lwb 1/2 ton) and 3600 (lwb 3/4 ton) are the same frame. FAM sect 2 sheet 26.00
3800 1 ton has a heavier frame that goes straight over the rear axle
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-13-2014, 04:11 PM | #3 |
do you know about a 3100 swb 1/2 ton?
05-13-2014, 07:24 PM | #4 |
it's longer
05-13-2014, 07:39 PM | #5 |
link in my signature sends you to a site with spec manuals for the different years. There is a frame section that gives the difference in width, depth and thickness of the frame channels. It also has wheelbase, track and other dimensions. The link lands on a 56 truck page, scroll down and click on the year index tab to get to the menu for different years.
05-13-2014, 08:56 PM | #6 |
thanks guys! exactly what i was looking for!
05-13-2014, 09:08 PM | #7 |
The big difference between a 3100 frame and a 3/4 ton frame besides length is that the 3/4 ton frames are pretty well straight all the way back from the cab mounts while a half ton frame be it short or long bed spreads out at the rear to 40 something (not taking the time to look it up or measure now) inches .
If you had a good 3/4 ton frame that you were thinking about shortening to put under a short bed the only big issue would be the width of the frame at the rear and needing a notch in the back if you decide to lower the truck any.
05-14-2014, 11:04 AM | #8 | |
3800 frame is straight over the rear axle
05-13-2014, 09:22 PM | #9 |
going to put my trans am clip on my frame and was just brain storming some things... It will stay a long bed for now. Big notch over the rear axle 4 link, bags.
Where do you think i would need a notch in the back if i decided to lower it? |
05-14-2014, 11:06 AM | #10 |
usually the notch goes over the axle
05-14-2014, 11:56 AM | #11 |
LOL i know, i guess i was thinking there was somewhere else if i made it a short box, but i should be set now!
