Old 05-15-2014, 10:59 AM   #1
trkfrk
trkfrk's Avatar
Need help mounting stock LS1 fuel pump in my tank
Hey guys, I have been looking for awhile now and I am not able to find a way to install the factory GM fuel pump into my tank. I am trying to avoid buying a new tank and really want to stay with the GM fuel pump. With so many of us doing the conversions you would think there would be an aftermarket mounting kit you could bolt in or weld. I have already modified the tank by welding in the filler neck and installing a baffle inside. Any help would be appreciated. Here's a picture to help clarify.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 05-15-2014, 11:17 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Need help mounting stock LS1 fuel pump in my tank
Something like this? Not sure it will work on an aluminum tank, but you could probably copy it and make one yourself out of aluminum. http://www.vetteworksonline.net/cata...products_id=89
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-15-2014, 11:46 AM   #3
trkfrk
trkfrk's Avatar
That's perfect I think I'm going to try and copy it out of aluminum so I can weld it on. Thanks for your help!
Mark
Old 05-15-2014, 09:19 PM   #4
69cunningham
69cunningham's Avatar
Take a look at my build. I welded a ring to the top of the tank.
http://67-72chevytrucks.com/vboard/s...d.php?t=610252
69cunningham is offline   Reply With Quote
Old 05-16-2014, 01:12 AM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: Need help mounting stock LS1 fuel pump in my tank
I took the rig and matted it to another tank ring and cut it out then cut a hole in the tank to remount with sheet metal screws and a good gasket. Simple no welding. It has leaked a drop since back in the early 90's when I did the TPI swap.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-16-2014, 09:45 AM   #6
trkfrk
trkfrk's Avatar
That came out really nice and looks clean! I am going to attempt to make the plates this weekend. It looks like you tapped the bottom plate with treads correct? Thanks for the help.
That definitely sounds easier to do. Do you happen to have any pics? Thanks
Mark
Old 05-16-2014, 07:35 PM   #7
trkfrk
trkfrk's Avatar
Thanks for everyone's help. I used some hole saws today. This is what I've done so far. I still need to drill and tap my threads and weld the bottom plate in the tank.
Mark
Old 05-16-2014, 07:38 PM   #8
trkfrk
trkfrk's Avatar
Pic 2
Mark
Old 05-16-2014, 07:48 PM   #9
trkfrk
trkfrk's Avatar
If you decide to make your own plates I used 1/4" aluminum plate. Cut your opening on your tank 3 1/2" so your O-ring can sit on. The bottom plate that is going to be welded to the tank hole saw ID 4" X OD 6". The top ring ID 3.50" and OD is 6".
Mark
Old 05-16-2014, 09:21 PM   #10
69cunningham
These look very nice. I did mine similar. I did drill and tap the bottom ring.
Old 05-19-2014, 08:20 PM   #11
trkfrk
trkfrk's Avatar
Thanks again for the help. Everything is done
Mark
Old 05-20-2014, 10:21 AM   #12
littlevictories
looks killer! that pump has a built in vent right? gotta have that vent, I learned the hard way, lol.
littlevictories is offline   Reply With Quote
Old 05-21-2014, 11:44 AM   #13
trkfrk
trkfrk's Avatar
I'm not sure. I will take a look at it. Thanks for the heads up. I did find out GM discontinued the fuel lines on the actual pump. I ended up going to my local hose place and found some lines.
Mark
