05-19-2014, 02:51 PM | #1 |
Ext Reg to CS alternator-I know...
I have the cs130. I have the harness with the built in resister that goes from the ext reg alt to the CS.
Do I simply plug in the plug into the harness and then the CS end into the new alternator?? or do I have to do the cutting and jumping at the ext reg?? Someone please give me very simple, 12 year old instructions if I need to, . Thanks Last edited by hardwaycooke; 05-19-2014 at 10:13 PM. |
05-19-2014, 02:58 PM | #2 |
67-72 parts collector,…
Re: Si to CS alternator-I know...
Does this help?
http://www.novaresource.org/alternator.htm
05-19-2014, 03:05 PM | #3 | |
I'm going from SI ext reg to CS int reg and have the resister adapters from AC Delco. Help me people... |
05-19-2014, 03:49 PM | #4 |
I have the same adapter. I believe you still need to do the connecting at the external regulator harness. I have not got that far yet.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
05-19-2014, 04:10 PM | #5 |
this will answer all your questions if you take time to read it , actually it is concise
http://madelectrical.com/electrical-tech.shtml
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
05-19-2014, 06:42 PM | #6 |
05-19-2014, 04:39 PM | #7 |
Carpe manana
Not sure this helps but I got the jumper harness kit that bridges the OEM alternator connector to the int regulated alternator. The kit also has a rubber "stopper" that plugs into the harness connector for the ext regulator. It's clean and that easy.
05-19-2014, 06:43 PM | #8 |
Where did you get that?
05-19-2014, 09:58 PM | #9 |
Carpe manana
See here: http://www.classicheartbeat.com/Elec...%20harness.htm
Plug and play - easy and does the job right with no harness mods.
05-19-2014, 10:06 PM | #10 | |
05-19-2014, 10:44 PM | #11 |
Carpe manana
Not sure - the harness are available for CS and SI type alts if that helps.
05-19-2014, 06:54 PM | #12 |
There are a billion pages on how to convert from external to internal regulator. If you want to be fancy you can hack up a spare regulator and do the mod internally as well, but I just loop the wires as per normal. Can't see the regulator under the battery box anyway.
But what's this about a resistor? Is it some weird requirement to get the field jump started or something? I've never heard of a resistor in the adapter, not have i had a resistor in any of the half-dozen or so conversions I've done, all of which worked fine...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-19-2014, 07:44 PM | #13 | |
Still not getting that...LOL.. |
05-19-2014, 08:01 PM | #14 |
Try doing a dn to a cs conversion
05-19-2014, 10:10 PM | #15 | ||
Msgt USAF Ret
....http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-19-2014, 10:12 PM | #16 | |
05-19-2014, 09:56 PM | #17 |
Ok. Talked to the guy at madelectrical. He said a cs130 140amp alternator was overkill for my application, no stereo, no electrical fans, no a/c...and said a si12 100 amp was plenty and that he definitely would not use the cs130 140 with an ext wire jump like I've been reading about. He said new wiring is best and even with my higher end ignition components a 65-100 si is plenty.
So there...but since I have the cs130, I'm gonna hook it up and see for myself. |
05-19-2014, 10:08 PM | #18 | |
Should I just get a Si12 int reg and send the cs back?? |
05-20-2014, 12:39 AM | #19 |
I have a CS130 in my '87 Vette and it's the last alternator I would take the time to put in my truck. I'm on the third or fourth one. Granted, Vette underhood temperatures are a lot higher than most '67-72 trucks, but that alternator can't stand the heat. The CS 130 has one external fan and one internal fan. The CS130D is a different animal and has two internal fans. I have read about many guys with C4 Vettes, switch out the CS130 for the CS130D or later model alternator.
>>cs130 140amp alternator was overkill for my application, no stereo, no electrical fans, no a/c...and said a si12 100<< The guy at madelectric is more than correct. My '67 has a small dash Stereo with Bluetooth, Digital Climate Control AC, trailer brake controller, HEI and two fans on the radiator. Only one fan works because the second one is on an overheat thermostat. The alternator is a 10DN with External regulator
'67 GMC 2500, 292, 4spd, AC |
05-20-2014, 02:37 PM | #20 |
Ah, that makes sense. In a normal setup (ie: every one I've done before) I've always included the idiot light. That voltage differential (sense line) must be important for some reason.
As for size, you need to scale it to what you're running. My truck really has no additional extra load beyond stock, but if you've got dual electric fans and a big electric fuel pump and extra lighting and so on, then it becomes an issue. My Range Rover, for example, has a heated windshield, heated rear window, heated steering wheel, four heated seats, and on and on. That's why it has a monstrous alternator (sounds like close to 200A just adding that stuff up at 12V) that they literally liquid-cool. Only liquid-cooled alternator I've run across.
