05-19-2014, 08:13 PM | #1 |
Drop Spindles #
Hello, I have bagged my 72 1/2 ton suburban and would like to add drop spindles.
Do anyone have a product # for a set of 2 or 2.5 inch spindles that does not require changing ball joints or other parts? DJM or Western is what I would like to use. Thanks for the response. |
05-19-2014, 09:31 PM | #2 |
67-72 parts collector,…
Re: Drop Spindles #
For a direct bolt on spindle, make sure you get a 71-72 specific spindle.
The board Vendors should be able to help you. Otherwise look at Summit Racing.
05-20-2014, 11:02 AM | #3 |
Re: Drop Spindles #
Thanks, for your help.
05-20-2014, 11:39 AM | #4 |
Re: Drop Spindles #
Choices from Smmit Racing since no Vendors replied,...
http://www.summitracing.com/search/y...drop%20spindle
05-20-2014, 03:10 PM | #5 |
Re: Drop Spindles #
So I guess that the 2" drop spindles will be the safest way to go with my wheels. 15x7 fronts and 15x8 rears.
Thanks again. |
05-20-2014, 03:39 PM | #6 | |
Re: Drop Spindles #
There are 2 different brackets. One for 12" rotors (stock), and one for their larger 13" rotors when you use CPP's "Big Brake" kit. This one is for the 12" rotor. http://www.summitracing.com/parts/cl...del/c10-pickup Personally I would just run a 2.5" drop spindle with the built-in /cast-in caliper bracket. Belltech, Western Chassis, McGaughy's or Early Classic Enterprises would be my choice.
06-08-2014, 10:32 AM | #7 |
Re: Drop Spindles #
Thanks Lolife99 for your help with this. I got the CP4S3 drop spindles from summit.
Thanks again. |
06-08-2014, 12:29 PM | #8 |
Re: Drop Spindles #
Man that looks good!^^^
That's low. Air ride???
06-08-2014, 12:54 PM | #9 |
Re: Drop Spindles #
Thanks, it's has bags from AVS, 2" rear blocks from Boris, 2.5 drop spindles, 450C Vaiar compressor with a 4 path Analog System setup. The picture isn't completly aired out, but I will be adding a c-notch soon and removing the rear bags hats.
It also has front and rear swaybars. Just a simple set for a better ride. |
06-08-2014, 01:01 PM | #10 |
Re: Drop Spindles #
It also has front and rear swaybars and front and rear shock reloctors. Just a simple setup for a better ride. |
