05-20-2014, 12:59 PM | #1 |
Front End Conversion Year?
Just put new front wheel bearings and seals last weekend. Need some help for future reference. Front end is only thing I haven't rebuilt on my '67. Previous owner or someone put disc on front. Bearings were found to be for HD rotors. My '67 has 2" CPP drop springs (found # on em) and Chassis Tech drop spindles (unsure of drop amount no numbers). The upper control arms have bolted on ball joints.
Sooooo....How do I tell what year of parts I currently have on truck so I can buy in future when they wear out? I bought the bearings for a '75 but found those crossed with a bunch of other years. I'm guessin I have mostly a 73-87 setup but I'm not for sure. How to tell? Give me any and all info. Thanks |
05-20-2014, 06:20 PM | #2 |
I'm just glad to be here!
Re: Front End Conversion Year?
With the information you gave, its a bit hard to know exactly what you need as there are alot of options within the same parts listed....
Wheel Bearings - you stated that you used '75 model HD bearings. This leads me to you have 1 1/4" thick rotors. If so, then any year '73-'87 with the 1 1/4" rotor wheel bearings work. Ball Joints - This can be tricky...All upper ball joints from '63-'87 trucks bolt into the same mounting pattern as you described. Question for you: Does your Upper and/or Lower A-arms have rubber bushings or steel bushings? Rubber bushings started in 1973. Outer Tie rods - This can be tricky too...many companies sell drop spindles that are year specific and that effects the ball joints and tie rod ends. Some pictures of what you had could/would be helpful for others to help you get the info you are looking for.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-20-2014, 06:47 PM | #3 |
67-72 parts collector,…
Balljoints, tie rods and spindles all have to match.
73-87 would all be the same. Bearings will be rotor specific. Just like the calipers. 1" light duty or 1-1/4" HD rotor width.
05-20-2014, 06:48 PM | #4 |
Pics of your suspension would also help.
05-20-2014, 08:32 PM | #5 |
Pics wil follow. Later or tomorrow. Thanks for help.
05-22-2014, 11:06 AM | #6 |
Ok here comes some pics........hopefully...........
05-22-2014, 11:09 AM | #7 |
1.
05-22-2014, 11:11 AM | #8 |
2.
05-22-2014, 11:13 AM | #9 |
3.
05-22-2014, 11:14 AM | #10 |
4.
05-22-2014, 11:16 AM | #11 |
5.
05-22-2014, 11:17 AM | #12 |
6.
05-22-2014, 11:23 AM | #13 |
I'm guessing I've got 73-87 rotors, calipers, and pads.
I know I've got HD rotors. No idea of ball joint or tie rod year(s). Guessing stock year control arms. Guessing stock year match for the Chassis Tech (no part #'s) drop spindle. Educate me. |
05-22-2014, 11:33 AM | #14 | |
A-arms could be 67-70 or 71-72. Steel brake line routing is on the front of the crossmember, which means 71-72. My "guess" is 71-72 drop spindles. The ONLY WAY to know for sure,... is to verify the UPPER ball joint or the outer tie rod. They will be either 71-72 specific,... or,... 73-87 specific. Take one or the other to a parts store and verify what you have.
05-22-2014, 11:50 AM | #15 |
^^^ Much appreciated.....again lolife99.
If anyone is seeing anything else let me know. Thanks. |
05-22-2014, 05:45 PM | #16 |
Follow Keith's advice. I see the same thing...
05-22-2014, 07:30 PM | #17 |
Guys... arent those slide on rotors? It looks like the lugnut studs arent pressed in the rotor
Im probably wrong but im just noting what I see.
1967custom |
05-23-2014, 09:59 AM | #18 |
Nope, those are not slide on rotors. I have seen some with chamfers on that side of the rotor at the lug holes...
05-23-2014, 11:50 AM | #19 |
Ya they're not slide on.
