Old 05-22-2014, 07:35 PM   #1
wdsteeves
Question Bleeding 4 wheel cutting brakes
Have a truck that has 4 wheel cutting brakes. Does anybody know the correct way to bleed the system? They are plumbed in to the stock system. I have bled the brakes on the truck but they aren't what they should be. Any/all input appreciated.Thanks
wdsteeves is offline   Reply With Quote
Old 05-23-2014, 11:39 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Bleeding 4 wheel cutting brakes
Out of curiosity, what are cutting brakes?
95 S_Trucker is offline   Reply With Quote
Old 05-23-2014, 11:50 AM   #3
wdsteeves
They are additional valves, controlled by hand levers, plumbed into truck brake system to activate the wheel brake of your choice to enable vehicle to skid steer(lock up wheel). Sand rail and dragsters use them to keep going in straight line. They are used in 4 wheeling to assist in tight cornering etc.
Old 05-23-2014, 01:44 PM   #4
95 S_Trucker
I see. That's kinda like what I have on my tractor then. Sorry I could not help at all, but thanks for the knowledge.
Old 05-25-2014, 03:38 PM   #5
OrrieG
OrrieG's Avatar
Know nothing about them except to the 70's sand rails that used the ebrake cables. It seems you would do just like regular, build up pressure and start with the line/fitting farthest away from the MC and work your way back. IF there are not any places to trap air should go ok. I assume the hand lever/valves have bleeders? I found speed bleeders make it go a lot faster at least on regular disc/drum set up.
