Old 05-24-2014, 11:24 PM   #1
Firecap44
Lowering
I have an 87 2wd truck would like to lower it. So here's the question can it be done by cutting a round or two off coils and doing a flip in rear?
Firecap44 is offline   Reply With Quote
Old 05-25-2014, 08:05 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Lowering
Both will lower the respective ends of the truck. I wouldn't cut more than a single round though (opinion does vary on that)
If you want to go lower than that I would swap in drop spindles.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-25-2014, 10:20 AM   #3
Firecap44
Re: Lowering
How low will one round get and a flip in rear?
Old 05-25-2014, 01:21 PM   #4
tinydb84
tinydb84's Avatar
Re: Lowering
Likely 2 in the front and 5 in the rear.
David
Instagram: myfabguy
Old 05-29-2014, 11:17 AM   #5
CC69Rat
CC69Rat's Avatar
Re: Lowering
A coil spring works a lot different than it may appear. Us humans would think hey, it's 14" long.. If I cut one round out of it it's now 12" long. I get a 2" drop.
Think of it like a diving board. Let's say the board is 10' long. A 250 lb guy bounces off the end and the recoil puts him 3' in the air.. The board flexes whatever amount.
Now, cut 2 feet off the board. The same guy jumps off the end. The board will be stiffer and less recoil right?
Your spring is just a straight bar all coiled up to create spring tension. If you cut a round out of it you also lose the tension of what that extra round once held up (truck drops lower) and the spring becomes stiffer like the diving board example.
One turn in the spring will yield more drop than just the height difference. I'm not saying it's wrong to cut the springs. I have cut small block springs in my big block truck. Why?.. to reclaim that stiffness for the weight of my motor and still get the drop I was looking for.
Just make sure you get an alignment if you decide to do it.. and expect a little stiffer ride. Good luck man.
Laterz..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-29-2014, 01:25 PM   #6
SCOTI
SCOTI's Avatar
Re: Lowering
Laterz..
And..... While it's true the ride can potentially become more harsh than vs the un-cut coils, it's possible it might not be enough for the amount of drop the vehicle would now have & you run into an issue w/bottoming out easier.
The safe thing is 1-coil max. If you need more beyond that, I would recommend shorter coils w/a better (optimal) spring rate for the amount of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-29-2014, 03:57 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Re: Lowering
A single coil cut in the front, plus a pair of drop spindles, and a flip in the rear will give you a 4/6 drop, which works great on the '73-'87 trucks.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-29-2014, 05:28 PM   #8
SCOTI
SCOTI's Avatar
Re: Lowering
x2
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-30-2014, 02:00 PM   #9
PEDROSKI
PEDROSKI's Avatar
Re: Lowering
Im torn between cutting a coil or doing a drop spring. Already buying moog steering parts and bushing. Do I cheap out and just cut a coil?
Old 05-30-2014, 02:04 PM   #10
tinydb84
tinydb84's Avatar
Re: Lowering
I'm all for cutting the spring but there is a chance you pull your springs and they are all bent or different heights. Just FYI
David
Instagram: myfabguy
Old 05-30-2014, 02:50 PM   #11
SCOTI
SCOTI's Avatar
Re: Lowering
It's your call really.... If you don't mind getting back in there after a trial period then cut a coil off the current springs & see if you like it. If you don't want to mess w/the current springs & are already buying Moog parts:
Moog # 6082 722 lbs/in 6 cyl, and light v-8
Moog # 6542 842 lbs/in std v-8
Moog # 6102 1015 lbs/in bigblock, longbed c.s.
Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102
Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton
Fresh springs w/the appropriate rates. Cutting a coil will increase the rates slightly (10-15% from what I've read).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-30-2014, 03:09 PM   #12
PEDROSKI
PEDROSKI's Avatar
Re: Lowering
Thanks for the info gentlemen.
