need photo of rubber strip
Could someone take a pic of how to mount the rubber seal from the cab to the running board with the steel strip? no instructions with the new kit thanks. this is for an AD.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Re: need photo of rubber strip
I can't do a pic but just did this on mine. The kit i got had a long strip of rubber shaped li an L . I laid the rubber piece on the lip of the cab above the runnin board marked it through the holes on the lip . Then i drilled holes in the rubber and put the metal strip on top and used stainless screws i think # 10. you may have to inlarge the holes in the metal strip. Sort of made a sandwitch with the rubber between the cab and metal strip. Hope this helps.
ok thank you.
