where to find build sheets?
Anone know where the factory build sheet could be hidden in a 1968 gmc? Always knew they were hidden, just have no idea where..any ideas?
62 k10 235/sm420 68 ![]() 84 burb k20 350/700r4/14bsf/10b 3.73s |
Re: where to find build sheets?
I've seen people find them in the coil mesh of the back of the bench seat. Mine was not there, couldn't find one.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Like under the upholstery?
Between the wire and the burlap, from what I understand.
http://67-72chevytrucks.com/vboard/s...=370818&page=2 Post # 37 shows one in the seat.
Thanks! Gonna go search a bit
They were supposed to be thrown away, but it was usually just easier to leave them in place and build the truck up around it.
As mentioned, the seats are a good place to look. Also under the carpet, behind any interior trim (if any), under the dash, etc. Passenger cars often have them above the fuel tank but it varyies by model year, assembly plant and even by shift within the same assembly plant. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
No luck so far..but did find the rubber for my clutch pedal!! Hahaha
If I were to contact chevy with the vin, do they still have the build on file? Seems like a dumb question....anyone ever try?
#9 | |
http://www.gmmediaarchive.com/ K
![]() Join Date: Oct 2009
nope. But, make sure to check both the seat back and bottom - use a little mirror to stick back there - should be visible if it is in fact there. Mine had TWO build sheets on it when I took it apart. One on the back and one on the bottom. And neither one matched the truck... Ha. Someone replaced the seat with parts from two different trucks
Will search harder then...and behind the dash etc.
