c20 fuse block help
I seem to keep having trouble with this truck my question this time is about the fuse block. Both unfused ignition terminals are hot all the time what should i check for or how do i correct this problem i have to plug the ignition wire into a different terminal to get the truck to turn off when i turn the key.
Re: c20 fuse block help
You should have a place on the box marked ign. to plug into for that.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
I see where its marked ignition but the problem is the terminals are hot all the time they dont cut power when the key is in the off position
I would check the back of the ignition swtch and the wiring since the terminals on the fuse panel get their power from the ignition switch.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
