06-02-2014, 08:29 PM | #1 |
Bagged and 1 piece driveshaft ?
I have a 1968 Suburban with bags in place of rear coils no notch. I am going to install a Gearvendors overdrive next week and I am wondering if I can use a 1 piece shaft. The gear vendors adds 14" to the transmission length .
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-02-2014, 08:38 PM | #2 |
67-72 parts collector,…
Re: Bagged and 1 piece driveshaft ?
Sure.
As long as it will pass thru the trailing arm crossmember. Cycle the suspension to verify it.
06-02-2014, 09:11 PM | #3 |
Would flipping the trailing arm mounts on the cross member help with clearance of worsen the problem ?
06-03-2014, 04:47 PM | #4 |
My bet would be 'make it worse'.
