Old 06-03-2014, 12:48 PM   #1
Sklptrljay
Sklptrljay's Avatar
Axle swap question
I'm usually on the 67-72 board. I have a question for you guys.
Can I swap axles between a 4WD 6 lug and 2WD 5 lug 73-87 without modifications?
Thanks.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-03-2014, 02:14 PM   #2
Ski-me
Ski-me's Avatar
Re: Axle swap question
I believe the spring perches are the same on the 1/2 tons. If you get up to 1 tons, they may be different. You also need to verify the u-joint is the same, as well as the shock mounts.
As an FYI, I put a "same era" 8-lug SF axle under my 1/2 Blazer. Bolted right up and I was also able to use the e-brake on the new axle. I did have to upgrade my u-joint though. There is usually a conversion u-joint if needed.
If you were closer I'd have a 3.73 axle for you.....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 06-03-2014, 04:14 PM   #3
Sklptrljay
Sklptrljay's Avatar
Thanks for the response. I guess I should have been a little more specific. I am wondering if the axles themselves will swap into different rear ends (4WD/2WD). There is a 6 lug air locker for sale here and I was thinking if I could get 5 lug axles from a 1\2 ton to fit it would be perfect. I currently have a 5 lug 71 1/2 ton it would have to match.
Old 06-03-2014, 04:50 PM   #4
SCOTI
SCOTI's Avatar
Yes. With the 73-87 housings, they're the same spline & length.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-03-2014, 05:23 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yes, 12 and 10 bolt axels can go from 6 bolt to 5 bolt axels. But not with the other as far I know.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-03-2014, 07:26 PM   #6
TwoFiftyShifter
I had the same query. Blew a 84 K10 rear, buddy has an 86 C10 rear I can take. Both 10bolt 3.08.
I haven't done the swap yet, but it sounds like the axle shafts are the same splines, huh?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 06-04-2014, 09:42 AM   #7
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2014, 07:01 PM   #8
Ski-me
Ski-me's Avatar
I believe there is a spline difference in the front axle only (4x4) and it's either 87+ or 89+ that has 30 splines (if I recall correctly).
- Jeff
