Old 06-07-2014, 05:58 PM   #1
apocalypse
apocalypse's Avatar
C10 Suburban Rear-end Shaking
Hello All,
I have a question for all the knowledgeable people on here. When taking off and driving my 66 Sub, the rear-end is shaking. It's not bad enough to keep it from driving down the road, it shakes more taking off. I've recently put new shocks on. I thinking it's something in the brakes sticking or something like that. I just wanting to see if anyone else has had the same problem? Or might have some idea what could be causing it.
Thanks,
Mark
apocalypse is offline   Reply With Quote
Old 06-07-2014, 06:30 PM   #2
WEBBY1
WEBBY1's Avatar
Re: C10 Suburban Rear-end Shaking
Id get it up in the air and see if the wheels turn freely and check the dive shaft.
WEBBY1 is offline   Reply With Quote
Old 06-07-2014, 06:41 PM   #3
63burban
Chevy addict
Universal joints
63burban is offline   Reply With Quote
Old 06-07-2014, 09:11 PM   #4
apocalypse
apocalypse's Avatar
It has 2 driveshafts in it. Shorter front one & longer rear one. The only place there is any play is where the two meet. Kind of expect a little there. Could it be anything else?
Old 06-07-2014, 11:19 PM   #5
Captainfab
60-66 Nut
Bent wheel or separating tire?
Old 06-08-2014, 12:40 AM   #6
NEWFISHER
NEWFISHER's Avatar
Flywheel chatter if its a manual?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 06-08-2014, 01:38 AM   #7
Lowl!f3
Lowl!f3's Avatar
loose rearend
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 06-08-2014, 01:59 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Does it make a difference if its under load (accel) or (decel) or just coasting?
u-joints, carrier bearing if you have one on the subs (can't remember), posi slipping/clicking if applicable, driveline angle from worn trans or motor mounts or rear end isn't aligned with the trailing arms.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2014, 02:05 PM   #9
hopped up
hopped up's Avatar
Carrier bearing
hopped up is offline   Reply With Quote
Old 06-08-2014, 08:21 PM   #10
apocalypse
apocalypse's Avatar
Was able to get under it today. It's the carrier bearing, it's shot. Going to replace the universal joints as well, while I'm under there.
Thanks for all the advice and what to look for! Really appreciate it guys!
