06-07-2014, 10:31 PM | #1 |
Broken Front Spring Hanger
'71 GMC Jimmy K/1500 -- 350/SM465/NP205/3.73 12-Bolt Posi.
The forward Drivers Side Spring Hanger is broken in a few places, cracked and the rivet holes are busting out. One rivet is loose. I have a hell of a wobble over 25 MPH, so I can't drive it. I think the Power Steering muscles it around. I also have a '72 parts Blazer tub. The Hanger assembly looks OK, but it looks like there are 8 3/8" iron rivets holding it on the frame. How do I get it loose to R&R onto the Jimmy?
06-08-2014, 05:36 PM | #2 |
Re: Broken Front Spring Hanger
You're going to have to grind/cut/drill the rivets to remove the spring hangers, then use grade 8 bolts to reinstall the good spring hanger on your Jimmy.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-11-2014, 02:03 PM | #3 |
Does it have to come off as a whole unit, or can I separate the lower part with the spring hanger from the upper part with the body cushion to the bottom radiator wall?
06-11-2014, 10:06 PM | #4 |
You should be able to separate the lower bracket from the upper part that holds the radiator support. I looked at mine and it looks like there's just two rivets attaching the upper & lower brackets.
06-11-2014, 10:17 PM | #5 |
Yeah, I see now. I'd rather not mess with the radiator.
The PO had tack-welded the spring hanger onto the frame. The dog-eared rivet holes are parted from the bracket. I see I'm gonna have some big grinder fun. Just to make life more interesting, the Stepside's battery burned out after only 6 years (!), so I had to cannibalize the Jimmy's battery just to have one good work truck. Pix below. Top shot is donor '72 K/5. I notice LMC offered [in the '05 catalog] a Spring Hanger Front, LH, P/N: 34-1340 for the '73-'91 series. How close is that part to a '69-'72 K/5's Spring Hanger? Thanks for your advice.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-11-2014 at 10:23 PM. |
