![]() Join Date: May 2014
Wanted three on the tree shift rods
I need the ones for a six cylinder mated to a saginaw 3-speed, likely only 68-72 will do.
I have a set of 1968 307 V8 to Saginaw and a set of 1967 6-cyl to muncie 318. I could sell or trade these if anyone is interested. The rods I am looking for are the ones that go from the column to the shift levers on the transmission (307 version pictured here) |
Re: Wanted three on the tree shift rods
The shift rods for a V8 and six cyl should & will be the same. Ive swapped to a V8 from a 6cyl many times and the bellhousing trans & clutch ,shift parts all worked perfectly. If your having a exhaust clearance problem you likely have the incorrect exhaust manifolds.
#3 | |
It might just be a case where I can cut them and weld them but with all the weird bends and so forth I'd rather just get a set of 6cyl.saginaw rods. |
I'll post up the pictures of the two sets I have in case it helps anyone else.
First set is the 307/Saginaw which look to be about 22" and 27" long. Second set are the 6cyl/Muncie which are about 24" and 27" long (and I am told they don't play well with the Saginaw 3-speed). |
#5 | |
#6 | |
Hoping Arrington01 can measure his and then we will know for sure. I haven't changed my motor but am changing tranny to syncro 3-speed from muncie non-syncro 3-speed. Gotta say this board is great for putting all the knowledge together...where else could you find this stuff.!? Ken (kitsbeach) |
I converted a 66 pk from the early Muncie to a later full syncro Saginaw. I had to change the bellhousing for one with a larger diameter center hole for the Saginaw front bearing retainer. The rear outpuit was fine splined so the rear yoke needed changed. The original trans was short tailshaft. so the driveshaft was shortened. I used 69 shift rods but they where too short. so I cut them in two. they are hollow. I used steel rods that fit inside to lengthen them. After I converted I found first gear in the Saginaw trans wasn't as low a ratio as the original Muncie. Ive since learned there are rings on the front inpuit shaft that can be used to identify the saginaw gear ratios. For all the work it wasn't that much better. The old Muncie if you shift to second before stopping and still have it in second gear when stopped it will easily drop into first gear without any grinding.
I have a mailbox in Washington 98281 if that's easier for anyone...???
![]() Join Date: Feb 2008
I think I have some.
The 66 GMC 1/2 ton Zombie truck that is my daily driver has a factory granny 4 speed. I wouldn't trade it for a three speed. I reciently sold a 65 half ton that we bought from the original owner. we owned it about 15 years, rust free good running truck. However the badly worn collum shift was very tricky. It took a expert to shift it. Its kinda rare to find a factory 4 speed 1/2 ton. Most conversions the floor pan is hacked up and the driveshaft cobbled together. The home brew jobs usually vibrate and are hard on U joints and the bearings & seals on the trans & diff. Now there are lots of different versions of shift arms that bolt to the side cover of a Saginaw trans. You will need the correct ones for your application.
Tough call because as you say the 4-speed is in there and running good but I have the old nostalgia for the three on the tree.
I have shift rods if your interested in them.
#15 |
Here is a pic of a set from a six cyl with a three speed saginaw that I'm buying from one of the members (thanks Jason).
Thought I'd post the picture here so that others could compare if they need to. I won't get around to swapping the three speed back in for a few weeks but when I do I'll post up any progress or lessons learned. |
#16 |
No problem. I am glad I could help you. I have a 3spd column to if you need one. Came out of a real low mileage truck. Thanks Jason
