R12 Conversion to R134A?
I know my compressor is good and original but not sure if system was converted to R134A... the high and low pressure fittings look newer than original vehicle. I just put a belt on the AC compressor and it runs. I know the system has some pressure on it but it does not get cool when I turn on AC. Should I look for someone to just add some R12 to the system and see if the AC will work or do I need to just convert the system over to R134A? If so, what is the best way, economical way to do this? Or is it best to just put R12 in and do it next winter once it cools off. Any advice is greatly appreciated.
Respectfully, Adam 1977 Chevrolet ![]() |
BAD BOW-Silverado XST
Re: R12 Conversion to R134A?
Is the condenser stock? R12 and R134 use differenty styles of condensors. If you run R134 through a R12 condenser, it will not cool down enough. Each uses a different amount. Each has different operating pressure too. Specific R134 condensor and new hoses are needed for R134.
#3 | |
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
My truck came retrofitted but hey its good to know the government wants to switch to that stuff that is $150 per can, isn't it?
They haven't got it done yet some I'm hoping they won't be able to. |
#5 | |
He informed me that the difference would be minimal @ best (indicated I might see a 1-2° difference @ the vent max). He said I would see better gains ensuring the pressure & freon/oil amounts were optimal for 134a & that was the most common mistake when people complain an original condenser wasn't effective after a 134a conversion. After telling me that, he said he would be glad to sell me one but wanted to be honest about any improvements (this being a BBC/TX heat application). My 90 was converted to 134a w/original parts & chills you out. My buddies Jeep Gran Cherokie was converted using original stuff & can freeze you out @ lower speeds. I stuck w/the OE sized unit for my BBC/CrewCab application based on how well those others worked. If I'm not happy w/it, I'll have a true Parallel flow custom unit built w/the largest dimensions possible (Parallel flow = better than 'tube & fin' R12 unit or standard 134a compatible Serp units).
#6 | |
So - those of us who use them just to haul our own selves around, at curb weight, are not taxing the cooling systems that much. I remember the time I heard a Powertrain cooling engineer say "...we could take some radiator out and save money" I didn't know what he was talking about. ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Everything to my knowledge is stock except the 1995 Tahoe 350 V8 that was installed before I bought it. The original engine blew up.
![]() Join Date: Oct 2013
so, how do you flush out R12 since shops do not accept that discharge. then just fill system with 134a? so many different answers to a common need, especially with high temps already here in Calif
The cheap way:
Have any remaining r12 recovered professionally (unless you are equipped do do so). Screw on adapter fittings. Draw vacuum on for 30 minutes. Charge with 134a and an oil charge. Don't expect it to cool very well, don't spread half truths around the Internet about how 134a doesn't work. This was the cheap way, remember? ![]() The "right" way: Have r12 recovered professionally. Flush the condenser and evaporator to remove any debris and old oil, make sure you get all the flushing solution out. Don't flush the rubber hoses, the tiny amount of mineral oil left in them acts as a barrier. If you want to get nuts replace the hoses, but it's not totally necessary. Replace the 30+ year old drier with a new one, the desiccant is no doubt saturated. Don't mess with the drier until last so as not to expose the desiccant to more moisture than absolutely necessary. Add most of the new oil to the new drier. Put a little oil in the evap and condenser. Probably wouldn't hurt to replace the orifice tube also. Assemble everything with new o rings, go ahead and replace them all, they're cheap. Put your fittings on and draw a vacuum for 30 minutes. Let it set for 10 minutes, it should hold. If it doesn't there's a leak, double check your work. If it holds, charge it up. Either way: Get the pressures close, but use them as a guide and use a thermometer in the center vent on recirculate to fine tune. You may find your system works best with the pressures a little off of what would be considered "right". Do it on a warm, 75-85 day, not a scorcher and not a cool one. Put a big fan in front of the grille blowing air through the condenser to simulate driving conditions and prevent high side temp/pressure from going off the chart and causing confusion and unnecessary over tuning. Dig out all the rocks and dirt from the condenser and straighten all the fins. It's tedious but makes a measurable difference in vent temp. Also, don't forget to check simple stuff like making sure the hot/cold blend door is sealing off the hot, or that the recirc door is closing. It's a good time to check the vacuum hoses, check valve, and put the reservoir back on (don't know why people take these off?). Make sure the blower motor has a good power and ground so it's moving as much air as possible. Last edited by kalbert; 06-09-2014 at 10:43 PM. |
my truck uses the stock condenser, with a small fan out front, and it will put ice on you, anytime. no need to use anything different. only reason I added the fan was when sitting still it was a little warmer. problem solved.
I flushed mine a long time ago, changed the oil to 134 stuff, and all new o-rings.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
I actually just flushed my entire system, replaced all the orings, replaced orifice tube and charged with oil and 134a today. Todays high temp was about 75-78 degrees I believe. I am running the stock R12 condenser. I charged with 3 cans of 134a. I have a brand new blower motor installed also and it blows hard. My idle temp on Max A/C was about 60-65 degrees but at cruising speed my vent temp was about 52 degrees.
I would really like to see at least 40-45 degree temps. Am I expecting to much??? On this forum someone suggested to use a Ford orifice (blue) and it would work better with 134a. So I did try this and used a blue Ford orifice. I think my low side pressure is around 45-48 lbs and idle
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
#12 | |
![]() Join Date: Apr 2009
Desert |
#13 | |
K
#14 | |
K
#15 | |
Its another one of those 2° tricks that alone isn't much but you add that 2° with the 2° you get from straightening all the condenser fins and the 2° you get from this or that and you're seeing the difference between cool and cold. |
#16 |
Understood; thank you -
K
#17 |
Here is a writup for our trucks. Doing it the "right way" is best. I did it plus upgraded the hoses. The R134 molecule is smaller than R12. Over time, it will leech out of stock R12 hoses. R134 hoses have a barrier between inner and outter walls.
I won't argue with an A/C expert. Air flow across the condensor is important for cooling. Especially a low speeds. A R134 condensor will cooler better at low speeds or idle than an R12 condensor. The multicross flow tubes work better. |
#18 |
Just keep in mind, "best" will get you a degree or two temperature drop at the vent at best and you will spend 10 times as much.
#19 | |
I did purchase one when swapping parts on my dually project but it was strictly to be starting w/something that was 100% new (clean & straight, unobstructed fins) but I just went w/a OE replacement for ease of installation. I also optimized the placement of the oil & trans coolers as well to minimize the impact of 'dirty' airflow to the condenser vs how it was set-up from the factory.
#20 | |
#21 |
Haven't driven it long enough to worry about that. My 90 swb was done the same way though..... I typically drive around w/the fan on lower speeds & the young ladies usually turn the vent away to keep the airflow from hitting them directly so it cools well. I would have to put a gauge on it before I could give you an accurate discharge temp.
#22 | |
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
#23 | |
One thing I forgot to note, the compressor has to be up to the task. A 30 year old compressor that has been run on a low charge for half it's life probably won't be able to build high enough pressure to make the difference great enough. Unfortunately the only way to test the compressor is to charge the system and see what it can do. Last edited by kalbert; 06-10-2014 at 10:46 PM. |
#24 | |
#25 |
I had a compressor go bad a 2 years ago, I work at a shop and evacuated the r12 out but I did not get enough out to do a recharge so I went to r134. I replaced the compressor, old one had a screaming bearing, and nothing else. I pulled a vacuum on the system for 30 minutes and then charged it with about 90% of a full charge, I was told to do this because of the higher pressures r134 operates at. Since than the only downside I have noticed is it takes a minute or 2 longer to initially cool the cab. Other than that it still blows just as cold. I work at a ford dealer and think my ac will out cool a number of newer vehicles. I replaced only the o rings at the compressor, added oil to the new compressor and the retrofit fittings.
