67 c10 5x4.75 swap
Hey, I Have A 67 C10 That Im Swapping To Front Disk With The Pol 5x4.75 Kit using Stock Spindles, I Have A Local Machine Shop Thats Gonna Redrill The Rear Axles, Just Wondering If Anyone Knows Of A Factory Rear Drum That Will Fit The Stock Rear Brakes With The 5x4.75Bc Or A Budget Rear Disc Swap With Junk Yard Parts, Im On A Really Tight Budget, Thanks
Re: 67 c10 5x4.75 swap
A long list of everything that used that bolt pattern http://www.roadkillcustoms.com/hot-r...#axzz34DWRRmtc
Cadillac Seville's used the 8.5 with disk brakes, as did the 90's Impalla often.
4th gen Camaro's are a easy adaption too. |
Use 5-lug truck drums & re-drill the smaller pattern when you get the axles done (it's easier vs welding up one of the 6-lugs stud holes & re-drilling them).
