06-12-2014, 07:25 AM | #1 |
Front suspension swap will this work
I am look to upgrade my front suspension on the 67 c20. I know you can swap in the 73-87 a arms to get the better bushings onto the 67 cross member, my main question is there is a swap to change from 8 lug to six lug using 1988 - 95 spindles with lower c20 a arm and c10 upper on a 1967-72, can this be done using the 73-87 a arms on a 67 cross member to get the better ride and get the 6 lug wheel setup. If it will all work do you need a c10 upper and c20 lower a arm form the 73-87 trucks?
06-12-2014, 11:12 AM | #2 | |
67-72 parts collector,…
Re: Front suspension swap will this work
Search the CaptainFab threads. Personally I would use the standard 5-lug swap with aftermarket 6-lug rotors. But just remember most of your 6-lug wheel choices are for the 99-up Silverado trucks,... (unless your order custom offset billet wheels). They use a wheel with a smaller center bore and much more wheel backspacing. There is a TON of info on this subject. If you have trouble searching this site,... search Google. It will bring you back here anyway.
06-13-2014, 10:07 PM | #3 |
Two easy choices
1. 71 or 72 1/2 ton complete crossmember, direct bolt in 2. 73-87 1/2 ton complete crossmember, drill a couple of holes. Aftermarket 6 lug rotors as mentioned above if you want to keep 6 lug wheels Don't get overly wrapped up in trying to mix and match parts front three generations of trucks. You won regret it. |
06-14-2014, 12:47 PM | #4 |
I've been down the 88-98 spindle road and I recommend staying away! Find another way.
