Old 06-13-2014, 09:52 AM   #1
hfd410
hfd410's Avatar
heads/cam combo advice....
My 71 has a newly built .060 over 4bolt 350 with 882 casting iron heads. Edelbrock performer intake, HEI, Edelbrock 650 carb, sanderson ceramic headers, 2 1/2" exhaust with magnaflows, and a comp cams XE274H flat tappet cam. I have a TH350 with the recommended stall for the cam with 3.08 gears. The engine runs great and starts immediately however I think it has more to offer. Everything is new and professionally built and I selected the cam based on what I wanted it to sound like vs perform. It sounds incredible by the way....Any help appreciated
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 06-13-2014, 10:21 AM   #2
geezer#99
geezer#99's Avatar
Re: heads/cam combo advice....
Lots of cam needs lots of initial timing.
What's your initial timing?
Old 06-13-2014, 12:28 PM   #3
rickpilgrim
Ign timing needs to be advanced for best performance.
If your heads are stock and not ported you've likely hit the wall of the 882 heads. XE274 is a lot of cam also, I would expect a weaker bottom end with that. You could also try Rhoda's lifters but that will soften the sound but work with your manifold/ header selection better on low end and still keep the mid/top strong
rickpilgrim is offline   Reply With Quote
Old 06-13-2014, 12:53 PM   #4
Gus350
68 C 10
Gus350's Avatar
To me and I'm no expert but if you want performance you have a good set up on motor . I think you need to look at the rear end 3.08 is grandma gears lol I would think 342'S with a posi would be lots better.
Kevin
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-13-2014, 03:02 PM   #5
hfd410
hfd410's Avatar
its about 18 degrees initial timing. And not that it matters but cylinders are .040, not .060
Old 06-13-2014, 04:27 PM   #6
hfd410
hfd410's Avatar
I guess what Im asking is if anyone has an opinion of a set of heads that would help wake it up...maybe some Vortecs ? I dont know much about heads and cams so any help appreciated. I realize that vortecs would be an intake and valve cover change also..
Old 06-13-2014, 05:34 PM   #7
hfd410
hfd410's Avatar
ttt
Old 06-13-2014, 06:08 PM   #8
Gimme Jimmy
Are you using the "dish" top pistons? If so use small chamber heads (65-67cc) some 1.94 327 heads work well for that application. If you are using flat tops, the 73cc heads will render a 9.3 to 9.5 comp. ratio. In any case, a big cam requires high compression to really "thump" and there are several ways to do that using combinations of small block parts that are relatively cheap and easy to come by.
Gimme Jimmy is offline   Reply With Quote
Old 06-13-2014, 10:13 PM   #9
hfd410
hfd410's Avatar
yes they are dishtop....I guess higher compression would help at low RPM ? It seems to have kind of a "flat spot" in the 1200-2000 RPM area
Old 06-13-2014, 11:43 PM   #10
rickpilgrim
As to low compression (less than 9/1) there are a lot of things in cam land that can really help. What you do is find a cam that increases your "dynamic" compression. In my 82 crew cab is a 355 with 8.75/1 compression with ported 487 heads w/ 2.02 1.60 tuliped undercut valves with screw in studs/guide plates roller rockers and stud girdle with double springs. It has a Holley 300-36 intake manifold topped by a Holley 3 barrel carb of 730 cfm or so. Runs dual 3" exhaust with H pipe and 50 series flowmasters.
I've got a crane cam of 226@.050 intake and 234@.050 exhaust with .490 intake .510 exhaust lift . I run Rhoads VVT lifters and have 160 psi cranking compression and it revs to 6500 rpm fairly quick and in that 5800 lb crew cab is ok below 2500 but comes on like a freight train after that and has been checked with a certified speedometer to 130 mph.
It's about dynamic compression and while static helps dynamic is what moves you.
Old 06-14-2014, 10:20 AM   #11
msgdsrf
You said 1200-2000 rpm. So thats really just off idle and cruising. Gears will make all the difference. You could also advance the cam a few degrees, that would make it play nice with the low compression. As for heads, that could help for sure but the 1200-2000 wont likely see a whole lot of benefit. 3.73 rear would do the trick.
msgdsrf is offline   Reply With Quote
Old 06-14-2014, 10:55 AM   #12
bigsnookmaster
bigsnookmaster's Avatar
I would go with small chamber World Products Sportsman II heads, Performer RPM Intake, and a 3:73 rear. This would wake things up quite a bit!
bigsnookmaster is offline   Reply With Quote
Old 06-16-2014, 07:21 AM   #13
67 chevelle
67 chevelle's Avatar
great advise
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 06-15-2014, 11:36 PM   #14
Econman
Econman's Avatar
With the dish pistons, you'd improve performance with Vortec heads.
Econman is offline   Reply With Quote
