06-14-2014, 11:18 PM | #1 |
Muddy looking brake fluid
My 76 C10 brakes went out Friday. The pedal goes all the way to the floor with very little stopping power.
I pulled the cover off and found the fluid a little low, and it has a muddy look to it. I had the calipers, brake shoes and one brake line replaced a couple of months ago. Do I need to replace the master cylinder or power booster or both? Should I bleed out all of the old fluid and replace with new? This truck was driven only about 1000 miles over the last 4 years. I just bought it in January. |
06-15-2014, 06:31 AM | #2 |
Re: Muddy looking brake fluid
I'd try replacing the fluid first if its no different then booster/master or both.
06-15-2014, 08:46 AM | #3 |
Check the rear drums for cylinder leaks. New rear shoes put the piston's in the cylinder in a different spot. If the cylinder bore isn't clean you'll get leaks along with a bit of brake dust drawn into the cylinder.
06-15-2014, 09:45 AM | #4 |
Robert Olson Transport
fluid swap to start then inspect everything else real well
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
07-11-2014, 05:53 AM | #5 |
The price of a new master cylinder was reasonable, so I decided to replace it and all the contaminated looking fluid.
The brakes are fine now. |
07-11-2014, 12:13 PM | #6 |
Brake fluid will absorb moisture over time, I drain mine when I restore/restomod trucks then if I keep them long enough I usually change the brake fluid every 2 years.
