Old 06-15-2014, 09:39 PM   #1
71chevydude
Idling problems
I have a 2000 chevy Z71 and I am having idling problems. It runs fine when it's still cold but after it gets warm it idles down past 500 rpms, I have changed the IAC sensor and nothing different. I changed the fuel filter and the same results. I checked all around the intake for air leaks and haven't found any. A buddy told me the cataylitic converters may be stopped up. I don't want to start swapping things out spending a bunch of money. Any help would be appreciated
71chevydude is offline   Reply With Quote
Old 06-17-2014, 09:54 AM   #2
Boog
laying low
Boog's Avatar
Re: Idling problems
You should start off with the basics.
have it scanned for codes and a look at vacumn, fuel trim, etc.
check fuel pressure
a good muffler shop can test the back pressure before the cats to help rule out a plugged up cat or muffler simply by removing the o2 sensor and inserting a pressure sensor. If there's blockage the truck will be down on power especially under wot.
a vacumn leak can be down under the intake manifold runners making it hard to locate. and these composite manifolds are prone to cracks.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
