Old 06-18-2014, 11:11 AM   #1
72tutone
Backspace question
Is the 15" rim the only issue with backspacing and an ECE 2.5 spindle? I'm curious if the bigger size rims will work fine without modifying the spindles. I.E Tierod boss in spindle as they are hitting my wheel now, along with the A-ARM. I already modified the a-arm gutter for clearance but the tierod spindle is still hitting the rim. Is it the diameter of the larger rims that makes them ok? Even if they have a bigger backspace wouldnt there still be interference issues? Or no, since everything tucks back in the wheel?
72tutone is offline   Reply With Quote
Old 06-18-2014, 06:18 PM   #2
72tutone
Re: Backspace question
Anyone running ECE spindles that can chime in?
Old 06-18-2014, 06:30 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Larger diameter wheels will help.
But it sounds like you have too much backspacing on your current 15" wheels.
Keith
Convert to disc brakes.
Old 06-18-2014, 06:33 PM   #4
lolife99
lolife99's Avatar
This 15" wheel has a 4" backspace.
This is the max in my opinion.
Your only choice is to grind some clearance on the spindle or change wheels.
Do you have any pics of the problem area?
Keith
Old 06-18-2014, 10:33 PM   #5
72tutone
Thanks lolife! Ur always a great help. I don't have any pics at the moment. I'm just trying to understand if larger diameter wheels have more backspace than what i had (6.5 rally) then how can the spindle fit OK? I'm looking at the ridler20x8.5 with 4.5 bs and 20x10 5.5 bs. So if the ridler wheels have as much if not more backspace then what I had, how do the larger wheels work? They simply tuckin the wheel?
Old 06-18-2014, 10:40 PM   #6
lolife99
lolife99's Avatar
Larger diameter 20'' wheels will clear the tie rods.
Keith
Old 06-19-2014, 07:02 AM   #7
72tutone
Ok cool. That was my assumption as well. Whereabouts are you located in MO Keith? Would love to look at ur truck. Stance is killer!
Old 06-19-2014, 09:00 AM   #8
72tutone
How about 18"?
