From "C to K" Evolution of my K-20
The truck is now near completion, so better late than never, here's some photos of some of the ordeal. I've owned this one for over 18 yrs and served me well. Wood hauler, rock, land fill, etc.
Being Overloaded snapped the trailing arms, so hence the makeover to the K-20 I've always wanted! ![]() ![]()
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Re: From "C to K" Evolution of my K-20
A little off center..
Did some quick research, this is where she was born... Janesville Wis.
Found a donor chassis from a 1970. Sm465, 205 transfer, all there for $350. I'm no fab guy really or body man for that matter. So I mainly just refurbish things to be as close to what they once were as best I can.
All new bearings seals, ball jts, ujoints, etc.. Has 4 in rough country lift springs. This chassis also rolled off the Janesville assembly line. ![]()
Started blowing it apart. These are not in exact order.
Found I had some welding to do.. Guessing this helped along the corroded fuse box and holes in the floor pan.
Thought that was cool. This was hand brushed on Under the green paint. Same number throughout the truck.
The pic above ^^ shows my cab on milk crates
![]() I'll post more pics tomorrow. Thx for looking.
Ehhh that rot looks Scarry! Gonna be a sweet truck when done! Guessing the trailering arm was rusted due to it snapping?
Yeah the trailing arm had a little more rust than I thought. Sheared brake lines, broke the torsion bar, shock absorber looked kind of like a horse shoe.. Wish I would have got a pic.
New floor pan, supports, welded and patched holes. Cab corners and rockers I did around 5yrs prior. Glad I was able to grind out that filler and redo it. Coated inside and out on the floor pan with por-15.
Quick little repair.
A little support repair..
#15 |
I was able to repair this one. Had to replace the passenger side.
#16 |
Switching gears here. Wiring had some corrosion in it with a couple broken spots. Had a spare I picked up and made one good one.
#17 |
Common practice was to blast parts and get them in primer, then put them in my basement until I needed them. This was done to keep from getting filthy in my shop.. For about 2yrs I had fenders, wood floor and anything else that would fit
#18 |
Got my wheels. Couldn't wait to hangem.
#19 |
Time to get back to the hoist.
![]() Getting fitted ![]() ![]() ![]() ![]()
#20 |
Daylight!! Pressure washed to really see what I got. I envy you guys with a heated well lit shop...
#21 |
Made it to a buddy of mines paint booth. First base clear I've dealt with, seemed somewhat trouble free.
#22 |
Some of the small and very time consuming things. Mainly saved these for bad weather.
#23 |
Looky what I found..
![]() ![]() Bought these from a board member. Rancho brand. I just changed color, still not sure if I'm going to use them. ![]() Here's my stainless they cut out at work. I was going to make exhaust with it, till I realized what a pain it is to work with. I traded it to a buddy for some work done. ![]() ![]()
#24 |
We ll see how this holds up..
![]() ![]() Rebuilt my wing windows thx to a write up on the 60 to 66 side. ![]() ![]()
#25 |
Had to have the hooks. Just completed the look IMO.
![]() My first cut and buff. ![]() ![]() ![]()
