Old 06-21-2014, 09:16 PM   #1
Michael_e
trans question
Will a 700r4 that was connected to a 4.3 bolt up to a 283 small block? will this trans handle the power of a stock 283?
Mike
Michael_e is offline   Reply With Quote
Old 06-21-2014, 09:38 PM   #2
T-P Auto
Re: trans question
Hi Mike;
I have a 700r4 hooked up to a 4.3 in my 95 chevy pu.
It had a 5sp in before.
I know that the bolt pattern on the block n trans are the same.
The 700r4 should do good behind the 283,unless you have beefed up the 283.
You will have to make or bye a NEW drive line as the 700r4 about 4" longer then reg trans.
T-P Auto
T-P Auto is offline   Reply With Quote
Old 06-21-2014, 10:46 PM   #3
Michael_e
Re: trans question
Thanks Tim!
Old 06-22-2014, 01:51 AM   #4
Donaldo
Re: trans question
You might consider doing thorough inspection of the trans and installing a thicker shift plate and hd clutches, just to be sure - and check the speedometer drive, some are mechanical and the others are electric.
I put a 700r4 behind a '99 350, the '51 should be a few 100 lbs lighter that the trucks they came out of.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 06-23-2014, 08:25 PM   #5
Michael_e
Re: trans question
Why would I want or need a thicker shift plate? I'm not necessarly looking for hard or tire burning shifts, just good, reliable service.
Old 06-23-2014, 09:16 PM   #6
Donaldo
Re: trans question
Why would I want or need a thicker shift plate? I'm not necessarly looking for hard or tire burning shifts, just good, reliable service.[/QUOTE]
Just for long term reliability. I have heard of complaints on the 700r4 getting weak at 60,000 +/- miles, and I plan on driving mine farther too. I'd just rather fix it the first time.....just sharing the idea.
Thanks, Don
Old 06-24-2014, 09:08 AM   #7
OneOffStroker
Re: trans question
I've had problems with EVERY 700R4 that I've owned. They have a design flaw with the valve body system that will turn the insides of your trans to silly putty it the T.V. cable is even a milimeter out of adjustment. However, theye are beefy, have a very low first gear, and a decent overdrive. They were the stock transmissions behind every IROC camaro and most C-4 Corvettes, so yes, they will work with a 283, and will definetly handle the torque just fine.
Here is a link to a valve body upgrade that will make your trans last, especially if you use a cobbled together T.V. cable & bracket that you wouldn't normally be able to properly adjust. I wish this would have been around in the early 2000's because it would have saved me 3 rebuilds and I'd probably still have my '89 IROC!
link: http://www.summitracing.com/parts/tci-376020
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 06-24-2014, 10:00 AM   #8
DransportGarage
DransportGarage's Avatar
Re: trans question
I'm not a 700-R4 expert but I did sleep at a Holiday Inn Express last night.
Here's a link to my 700-R4 build: http://67-72chevytrucks.com/vboard/s...d.php?t=490570
It would also be nice if Clinebarger reported in on this one to save you a lot of grief...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 06-24-2014, 10:57 AM   #9
DransportGarage
Re: trans question
Mike
The short answers to your questions are "Yes" and "Yes".
Bob
Old 06-24-2014, 11:27 AM   #10
mr48chev
mr48chev's Avatar
Re: trans question
I don't see a fairly stock 283 having enough more power than a 4.3 and it may not have as much hp or torque than some 4.3 engines, to get worried 700-R4 about.
The thing on a 700-R4 is and always has been the TV cable adjustment. It has to be perfect or else you have problems as Oneoffstroker mentioned in post #9. They just are not a forgiving trans if you get that adjustment off even the least bit.
My ongoing truck projects:
