Old 06-23-2014, 09:54 AM   #1
AZ1970k20
Differential Newbie
Hi Guys,
I just got my first K20 this weekend. I wanted to tackle my first differential gasket change. Sorry if some of my question are elementary. The forum has been great, and I have learned a lot from the other posts on this subject, but still have a couple questions.
1) Looks like there are two holes, one on the front side of the differential and one on the back. What is the difference between the two? I have not pulled them off to look yet, I figure, I would ask first.
2) If it is leaking oil on the side with the axle, what is required to fix that?
Thanks,
Seth
AZ1970k20 is offline   Reply With Quote
Old 06-23-2014, 10:17 AM   #2
Wrenchbender Ret
Re: Differential Newbie
The first arrow points to the ring gear thrust pad adjustment. The second is the fill plug. Neither look to be leaking enough to be concerned about. Remove the fill plug & see if the grease level is up to the bottom of the hole. Unnless the grease looks like it just came out of a can, which it won't, its a good idea to change it. Remove the bottom bolt from the rear cover. The grease will drain out but it may take overnight. Put the bolt back in & fill the housing to the level of the hole with 85/140 GL-5 gear lube. It will take about 3 qts.
Unless it leaves puddles on the floor or runs down the brakes it is not leaking enough to worry about.
_____
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2014, 10:33 AM   #3
AZ1970k20
WrenchBender Ret, Thanks for telling me what each of those were. Very helpful. Also love the idea how to drain the diff without pulling it off, very clever. Both were a mess yesterday, I cleaned them up with some de-greaser to see how bad the leak really was. That was one night of leakage. Still nothing to worry about?
Old 06-23-2014, 04:17 PM   #4
Wrenchbender Ret
I am sorry I made a bad mistake there. I meant to say unless it leaves a puddle or runs into the brakes it is nothing to worry about.
Old 06-23-2014, 04:53 PM   #5
Wrenchbender Ret
It seems to me you could fill it through the vent. It takes about 4 pints. You could raise the side of the truck that the vent is on so it would flow right into the housing.
Old 06-23-2014, 05:52 PM   #6
Tinkermc
Welcome to the Forum and we are all glad to answer questions, with pic's is much better.
Tinkermc is offline   Reply With Quote
Old 06-25-2014, 10:14 AM   #7
AZ1970k20
Thanks for the welcome and Thanks for all your help.
