Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-23-2014, 12:01 PM   #1
ratrodder
ratrodder's Avatar
Camaro front ssuspension?
I am getting close to starting my X275 truck build. I have a 67 C10 and I already swapped to a 87 5 lug disc setup. I am wanting the truck as light a possible (like 2700 lbs). Which means I want to run the Wildwood Dynalite Drag brakes. Well they dont make the kit for a c10. Is there anyway to run camaro front suspension? Or at the least spindles so I can get the dynalite brakes?
ratrodder is offline   Reply With Quote
Old 06-23-2014, 12:21 PM   #2
Super73
Super73's Avatar
Re: Camaro front ssuspension?
I am working on doing a mustang 2 spindle on my 63. This will have Willwood dynamite brakes.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-23-2014, 01:07 PM   #3
ratrodder
ratrodder's Avatar
How is that going? Drilling the spindles out to work? Or what?
Old 06-23-2014, 09:23 PM   #4
Super73
Super73's Avatar
Here is the link..
http://67-72chevytrucks.com/vboard/s...d.php?t=632411
Old 07-09-2014, 09:36 AM   #5
skeeterbug
skeeterbug's Avatar
I'll be watching this one very closely, i too need some serious weight loss in the front without spending major $$$$!! My current coilover rear with single adj. QA1's and 2" drop splindles, 1" drop springs with CE 3 way adjustable front shocks nets me little if any weight transfer, SUCKS!
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 07-09-2014, 09:58 AM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Originally Posted by ratrodder View Post
....... I am wanting the truck as light a possible (like 2700 lbs)....
That's an agressive target!!!
Has anyone gotten even close to that with a stock frame and steel body?
my 66 is at 3550 with backhalf of the frame whacked to 2x3 frame kit, fiberglas hood and fenders, and aluminum bed / no tailgate. I can't believe the 67 can have that much opprotunity to loose nearly another thousand pounds without a light tube chassis end to end and not a lot of steel body parts.. bu tam I wrong????
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-09-2014, 10:24 AM   #7
Super73
Super73's Avatar
Marv,
I agree it would take a lot to be there. I believe dj said his was down to 3,000 with his old BBC combo, not sure if that was with him in it or not.
Mine was 3,200 with me in it last time I was out but we know mine has had quite a bit odd weight reduction. I am at 200lbs
CM back half with 4-link
No front bumper
Modified front cross member
Summit light weight seats
No hood and cut out fenderwells
no tailgate
Old 07-09-2014, 10:54 AM   #8
Super73
Super73's Avatar
Oh yeah I forgot to add alum ls3 with powerglide.
Old 08-14-2014, 11:28 PM   #9
moggey01
My brakes are made from a camaro hub. It was machined to fit the c/10 bearing races. There is a spacer to load the back bearing from the spindle to get the right preload , Cory at The Brake Man did them for me.
moggey01 is offline   Reply With Quote
