Old 06-23-2014, 01:23 PM   #1
Budman56
Budman56's Avatar
Exclamation Need help with my pulley set up for my 65 v8
My pulleys don't line up, any suggestions? the steering pump doesn't line up with the crank shaft pulleys and the water pump pulley doesn't line up with any of them. The water pump is a short shaft all the pulleys except the one on the steering are original to the motor / truck. So do I have the wrong pulley for the steering pump? and did I put the harmonic balancer on too far?
Also I have a factory Air set up, Does any one have photos of what the belt configuration should look like? I cant find it in the shop manuals they don't show any photos of the front of the engine with all the options I have (power steering, air conditioning, driver side alternator)
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 06-23-2014, 01:26 PM   #2
Budman56
Budman56's Avatar
Re: Need help with my pulley set up for my 65 v8
photo of front end
MY 65 C20 BUILD
Old 06-23-2014, 02:02 PM   #3
pimpston65
pimpston65's Avatar
Originally Posted by Budman56 View Post
photo of front end
can you shim the WP pulley from behind with washers?
pimpston65 is offline   Reply With Quote
Old 06-23-2014, 02:04 PM   #4
pimpston65
pimpston65's Avatar
LT1burb has a great shot of the pulleys on his build, i used it as ref. for my build. them pulleys can be a pain, with so many out there good luck
Old 06-23-2014, 02:08 PM   #5
pimpston65
pimpston65's Avatar
just noticed you got the castiron boys, LT1 had the triple stake for the harmonic bal. your has the add-on type with a big space between the first and second pulley...
Old 06-23-2014, 04:17 PM   #6
Captainfab
60-66 Nut
You can not put the harmonic balancer on too far. It is supposed to bottom out against the timing chain gear. Now if that balancer is from a L31 Vortec 350 and you did not install the reluctor ring, then that would account for some of the alignment issue. Have you looked at this thread?
http://www.67-72chevytrucks.com/vboa...d.php?t=632007
nearly the same issue.
BTW It is against the forum rules to post duplicate threads in different sections.
Old 06-23-2014, 06:14 PM   #7
60-66
60-66's Avatar
For one, the power steering pump is from a 1969-1972 ish truck. I ran that pump on my 400 SB but I used stamped steel pulleys and ended up swapping the PS Pump pulley to get it lined up. You also do not need a double groove on that PS. That style pump and brackets pushes everything out further.
Find the pump that sits in a cradle with a stamped steel adjuster for your setup. Heres a stock setup similar to yours but the other style pump and brackets I mentioned.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-23-2014, 06:22 PM   #8
yelmer
check the damper width it might be to big
yelmer is offline   Reply With Quote
Old 06-23-2014, 06:22 PM   #9
60-66
60-66's Avatar
Edit !
Old 06-29-2014, 08:01 PM   #10
Budman56
Budman56's Avatar
Talking Re: Need help with my pulley set up for my 65 v8
Here is a link to the website that I found that has all the measurements for the pulley. http://www.alangrovecomponents.com/Important_Info.htm
MY 65 C20 BUILD
Old 06-29-2014, 08:13 PM   #11
Budman56
Budman56's Avatar
So I looks like I might have the wrong pulley on the power steering pump, so I called allen grove components and ordered a single groove pulley that measure out at 1 13/16" from the face of the steering pump, this should put the pulley back in line with the front pulley on the crank shaft. If this doesn't work I will need to order a new pump bracket that will put the pump forward and correct the line up issue.
MY 65 C20 BUILD
Old 06-29-2014, 09:40 PM   #12
pimpston65
pimpston65's Avatar
soo...Budman when you get the pulley situ. worked out please post, cuz i will(maybe) be running a simu. set i.e ac/ps/alt on a sbc, but i wont have the cast pulleys but at least i will know the proper spacing when i dig around for the correct ones. thks. btw love the blue frame!!!
Old 07-02-2014, 11:20 PM   #13
Budman56
Budman56's Avatar
Unhappy Re: Need help with my pulley set up for my 65 v8
So here is the new pulley, no surprise it doesn't line up. Back to the drawing board. I called Alan grooves again and this time I sent him photos of my setup, he told me that this setup is not factory. He goes on to say that the cast iron pulleys were after market back in 65 and that this was probably added at the dealer ship. Even the ac pump bracket was part of the kit and that it's not factory. Anyone know if this is true? The cast iron pulley has a GM number 3831397
MY 65 C20 BUILD
Old 07-02-2014, 11:37 PM   #14
Budman56
Budman56's Avatar
I still think I have a pump basket issue, but if you look at the photo the 6066 posted it look like it might be the same as what I have only I can't see the bottom of the bracket on his photo. Any suggestions?
MY 65 C20 BUILD
Old 07-02-2014, 11:45 PM   #15
Budman56
Budman56's Avatar
Lightbulb Re: Need help with my pulley set up for my 65 v8
I did notice something the pulley I bought and the one 6066 posted are different mine has more of a slop to the front which could be pushing it backwards and I think that is the 1/2" I need. But have been told no one makes a pulley like that. Does any one know if that is true?
MY 65 C20 BUILD
Old 07-03-2014, 08:31 AM   #16
60-66
60-66's Avatar
That's the reason I gave you the GM part number that IS correct for 1966. Its a Positive way of identifying parts. Your CAST pulleys are 100% GM and have the part number cast in them. Your power steering PUMP AND BRACKET are from 1969-1972 truck. This is what I said Im not certain they will work because it MAY be a different offset than the correct 1966 pump and bracket. Theres at least 3 different single groove PS pulleys, all different offsets . I can see right off that the one he sent you is the wrong offset. Is there a GM part number in this new pulley ?
Old 07-03-2014, 10:30 AM   #17
Budman56
Budman56's Avatar
6066 I must be slow because I don't see the part number you gave me, Can you give it to me again?
MY 65 C20 BUILD
Old 07-03-2014, 10:41 AM   #18
padresag
may be on the other thread
ron
padresag is offline   Reply With Quote
Old 07-03-2014, 10:42 AM   #19
60-66
60-66's Avatar
It was in your other thread on this issue, but I posted it above also. 3791943
Old 07-03-2014, 11:27 AM   #20
Budman56
Budman56's Avatar
6066 thank you I have copied and posted the photos of the pulley you have suggested here in this post, I have bid on the pulley so we will see if I am able to get it. Also as a side note I called Allen grove components again this morning to canceled the order I placed last night and talked to him some more about my problem with the pulley alignment and gave him the part number you gave me he says he has that part in stock but doesn't believe that is will fix my problem. Well see I will post when I receive / or win the pulley and install it on my truck. I am keeping my finger crossed and hope this fixes my pulley problem.......Thank you all for your input. I also noticed that woogo posted this in the FAQ for those who will have this problem in the future.
As a side note for all reading this is the correct GM PART NUMBER 3791943 FOR FACTORY AIR WITH CAST IRON PULLEY. PER 60-66
MY 65 C20 BUILD
Old 07-05-2014, 07:40 PM   #21
Budman56
Budman56's Avatar
Here is a link to Wiki link to the gm pulley it also as a link to ebay and will find the pulley if its on ebay at the time your looking for it.
http://www.gmpartswiki.com/gmpart?gmpartno=3791943
MY 65 C20 BUILD
Old 07-03-2014, 08:42 AM   #22
60-66
60-66's Avatar
Alan is correct in one respect, the aftermarket did make cast iron pulleys but it was for many different aftermarket AC systems and aftermarket AC brackets. So far everything you have on your engine looks correct and factory GM. But remember, most people have never seen original 1964-1966 truck factory air parts, especially when it comes to the engine pulleys and brackets, that stuff was discarded long ago if an air truck made it to the Midwest.
Old 07-03-2014, 10:24 AM   #23
60-66
60-66's Avatar
Here is a link to another post on the same problem on an AIR truck. We confirmed the PS pulley number 3791943 in post 21 from member HOTFUN as being correct. You can also see the correct PS pump and brackets in the pictures posted in the thread. You will notice a different water pump pulley in his pictures. The one on his truck was used on DEALER installed air, your pulleys are from FACTORY installed air . Same exact in dash air as yours though.
http://67-72chevytrucks.com/vboard/s...d.php?t=603125
Old 07-03-2014, 10:29 AM   #24
60-66
60-66's Avatar
And, here is that pulley
http://www.ebay.com/itm/1967-68-69-O...41abd5&vxp=mtr
Old 07-13-2014, 08:19 PM   #25
cortcomp
cortcomp's Avatar
I just went through this with a 327/air/ac/ps truck, had to add a 1/4 spacer to bring crank pulleys out to line up...water pump pulley couldnt go on more or itd rub the water pump housing. PS was slightly off but just came back from around 500 mile trip and no problems. Never did see if it was balancer or new.timing set that caused the offset. Excuse typos, typjng this on phone.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
