06-23-2014, 02:57 PM | #1 |
Brake Booster Guidance Needed
Hello all,
I am the third owner of a 71 Cheyenne 1/2T (avatar) with factory manual disc/drum brakes. Not knowing the truck's history, there are certain things that I feel like I should get new and completely replace, such as brakes. I am in the process of collecting parts to redo the disc brakes and I'd like to install a brake booster with new master cylinder and proportioning valve. I have already purchased rotors and loaded calipers from R1 Concepts, and the Timken bearing kits. Next I am looking at getting hoses and the booster. Will redo the drums on the rear shortly. As Brake boosters come in a variety of sizes: 7", 9", 11", etc., can I assume that the smaller the size the less "boost" assistance will be provided by the unit? If I plan on keeping a mostly stock vehicle, maybe a little lowering later, what is the smallest size I should I consider? Are there any other things that need to be considered? Any recommendations on brand and/or place to purchase would also be appreciated. TIA! -Ed Last edited by EdSevered; 06-23-2014 at 03:17 PM. |
06-23-2014, 04:38 PM | #2 |
Re: Brake Booster Guidance Needed
I used my existing master cylinder, which I rebuilt, my existing proportional value. I purchased OEM booster from a junk yard off a 71 and used it for a core. It gave me all the needed brackets. I think the OE is 11 inch. I bought a rebuilt one from O'Reilly's, worked great no issues
06-23-2014, 04:45 PM | #3 |
Just get a reman unit from any auto parts store. It's about a $20 core if you don't have your old one. Master is cheap too. The expensive part is the prop valve, if you want it to look anywhere near stock, they're something like $250.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-24-2014, 11:00 AM | #4 |
Thanks for the input guys, but I suppose I should get more to the point.
I am in the process of completely re-doing the brakes with new parts, starting at the front. I am going to buy a new brake booster w/MC and prop valve (disc/drum). I understand that the 11" booster is the size that would've been stock. But, if I want to use a smaller size booster to keep the appearance a little cleaner under the hood, will there be any mechanical or safety issues? Any recommendations on minimum size, brand, source, etc.? Thanks again! -Ed |
06-24-2014, 12:05 PM | #5 | |
06-24-2014, 02:19 PM | #6 |
If you are looking for a much smaller booster without sacrificing assist, then the easiest option is a dual-diaphragm unit. Packs twice the assist into a smaller package.
There's also the hydroboost option, which is pricier but also tiny.
06-24-2014, 06:35 PM | #7 | |
Thanks again, I hope I can repay the favor some day. -Ed |
08-23-2014, 05:09 PM | #8 |
Hello again,
I am in the collecting parts phase, preparing for several different jobs at the same time. I read in another power brake booster related thread that there may be some pedal related part(s) that I'll need to get to complete the conversion from manual to power brakes in my '71 c-10 1/2T. I already have a mc, booster, prop valve (disc/drum), with bracket assembly. And rotors, calipers, seals, hoses. Can anyone clarify? Thanks in advance, -Ed |
