Old 06-24-2014, 04:25 PM   #1
sambudo
sambudo's Avatar
interior ??
How do you successfully put on the clip to hold the door handles and window crank? Is there a secret to putting these on? Thanks
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 06-24-2014, 04:27 PM   #2
john
member #16
john's Avatar
Re: interior ??
install the clip on the handle and push on.
john is offline   Reply With Quote
Old 06-24-2014, 04:33 PM   #3
JointTech
JointTech's Avatar
Re: interior ??
I read that as well. I dont understand how if they are so !@#$% hard to get off how they can be so easy to put on.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-24-2014, 08:28 PM   #4
DUD2STUD
DUD2STUD's Avatar
Re: interior ??
Any parts store will have a tool that helps. Summit also sells one here's a link
http://www.summitracing.com/parts/sd...AiZJOvzUbw_wcB
DUD2STUD is offline   Reply With Quote
Old 06-24-2014, 10:05 PM   #5
jocko
jocko's Avatar
Re: interior ??
The shank is shaped so that the handle, with clip installed, can be pushed on. Once pushed far enough, the clip pops into the recessed ring of the shank and retains the whole handle. The tool is only required to remove the clip when you want to remove the handle by popping it out sideways. Remember to always install the open end of the clip pointing toward the long handle lever - this way you will always remember how to insert the tool - directly under the lever part of the handle, slide it in to engage the clips open end then keep pushing pushing outward, away from the lever part of the handle, to pop out the clip.
Anyway, to install, just install the clip on the handle itself, then pop/push it onto the shank.
