![]() Join Date: Jun 2005
72 Dana 60 4X4 Rear Housing.
This is a rear differential housing for a 71-72 Chevy/GMC 4X4 K20 truck.
The 2 WD housing is different, as the 4X4 housing have cast leaf spring pads with a more narrow spring stance and shock location. $150 First, I'll take it. Will ship, but it will be expensive! Can be picked up at Moultire Auto Fair in November or Charlotte Auto Fair in April 2015. 71-72 Dana 60 2X4 or 4X4 brake drums, almost new $75 plus shipping. 71-72 Dana 60 2X4 or 4X4 rear backing plates $60 plus shipping. |
![]() Join Date: Jan 2007
Re: 72 Dana 60 4X4 Rear Housing.
Hi interested in the brake drums shipped to PA 17517 thanks
Dan, I am passing at this time shipping is a killer! Thank you
Member #1049
Dan, Just in case you didn't know, that housing also is the same as a Big Block Longhorn.
![]() Join Date: Jan 2012
So the big block longhorns had the same narrow spring spacing as the 4x4 did?
![]() 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
Member #1049
Correct, all longhorns had the same spacing as the 4X4s, but usually only the Big block longhorns came with a Dana 60
Thanks for the input on the Longhorn fitment and the Dana 60. That's very interesting, but I can see why it was used to get the 3:54 gears for good pulling and a little better gas mileage. Thanks again, Dan
Info on the longhorn us correct mine is exactly the same 3.54 and all with the narrow shock mounts. figured this out the hard way when I bought another rear end to do a Disc brake conversion on and went to put it in and the spacing on everything was off but it was a dana 60 out of a c-20
I wish I was closer as I would take it for sure I need one for a project longhorn that is in need of a rear.
ttt
![]() Join Date: Mar 2012
do you have this housing still?
